Business logo
发表于 2021-9-1 00:11:06 | 显示全部楼层 |阅读模式
My wife and I designed a logo for my side business. Good thing somebody in the family knows computers. Took a few days of me changing my mind every thirty minutes but here it is. Attached ImagesShake and Bake
Reply:Always a hard thing to do - be objective about your own logo.You'll need a simpler version of it. It looks good in colour at a decent size on a computer screen, but sometimes it might appear in black and white. Or smaller. Or on a t-shirt. Or you might want to get it air brushed somewhere. Know what I mean?The best logos are usually only one or two colours and very simple.
Reply:I like it, and more importantly , you like it. I have been kicking around a few ideas and have not been able to come up with what I want. Good luck."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:nice logo, but may i suggest something?like said above, id make it black and white. that way it can be printed on anything with no problems.id also  try to get a actual logo in EPS format so it can be scaled to all sizes without distortion. because im assuming now you have it saved as a jpeg and itll hardly fit on a properly designed business card without some crazy pixelation.id be willing to help you out if youd like.Last edited by jcrazyjj; 04-15-2009 at 11:42 PM.
Reply:All very good ideas. I thought about the color thing also. Im going to see if the wife can do a black and white thing with it this afternoon. Good point jcrazyjj I think she has the image saved as 4 or 5 different files I will check and see if eps is one of them. Is eps the format that printing companies use??Shake and Bake
Reply:I like your logo.  Must have some special software for logos?I just bought a logo maker and it is not much good for welding logos.Encapsulated Postscript Image = EPSLast edited by Nitesky; 04-16-2009 at 08:37 AM.Reason: EPS infoGordie -- "I believe you understand what you think I said, but I'm not sure you realize that what you heard is not what I meant."
Reply:Originally Posted by JWCAll very good ideas. I thought about the color thing also. Im going to see if the wife can do a black and white thing with it this afternoon. Good point jcrazyjj I think she has the image saved as 4 or 5 different files I will check and see if eps is one of them. Is eps the format that printing companies use??
Reply:If your wife is using Photoshop you want to make sure she saves a copy in PS format.  Don't keep everything jpeg.  Keep a nice clean original.  JPEG file format compresses the image so it saves space, with this you lose quality.  This loss of quality will affect printing big time, you will notice a lot of "fuzz" around the image.If you are going to be doing printed flyers make sure she remakes the file in 300dpi(600dps would be good, however file would be huge) and in CMYK color format.
Reply:Nitesky, We got the picture off the net somewhere, and just played with the colors a little bit. It was some type of clip art site. I believe she used microsoft word.Shake and Bake
Reply:Thanks for the info DrmChld, it is saved as a bmp, jpg, and a png file. I will also save as a eps file.Shake and Bake
Reply:Originally Posted by JWCNitesky, We got the picture off the net somewhere, and just played with the colors a little bit. It was some type of clip art site. I believe she used microsoft word.
Reply:none taken jcrazyjj, the printer(Card Company) pulled everything up on her computer and everything was fine, just had to resize to fit the card. I guess if some printing companies cant convert simple home designs to cards, they dont need to be in business.Shake and Bake
GMT+8, 2025-12-23 10:59 , Processed in 0.092084 second(s), 18 queries .
