I wanted to share some simple, but strong, safe and inexpensive seat mounts I fabbed up this weekend. I am building a 1/4" drag car and I need to mount my seats. I decided to build everything myself and it only cost about $20 in materials for both seats -vs- $60 for a kit from some company that you would still have to fab up more brackets anyway.This setup is rock solid and will pass NHRA tech once the back brace is installed. Attached Images
Reply:Lookin really good ,did you mean 14ft drag car?Lincoln 225 ACLincoln Mig Pak 15Lincoln Mig Pak 10Purox Oxy-Acet Outfit20 Ton PressHonda Generator
Reply:I bet 1/4 mile drag car and I like the cage. Hope to see more pics as project continues.
Reply:I meant to say 1/4" mile drag car. It is a 67 Firebird, 25.5 cage. Should be good to 2500HP.I will post more pics as I move on with the car. Thanks for your replies!
Reply:Looks good carnut, did you fab the cage also?Shake and Bake
Reply:Originally Posted by JWCLooks good carnut, did you fab the cage also?
Reply:Originally Posted by carnut68I meant to say 1/4" mile drag car. It is a 67 Firebird, 25.5 cage. Should be good to 2500HP.I will post more pics as I move on with the car. Thanks for your replies!
Reply:I have a few more photos not related to the seat mounts, since others want to see more... here you go...The fuel cell is a custom 10 gal. tank I had made for the car since none of the pre-made ones would fit. I had them make a mini sump because I have the parachute mount right below the tank and a the standard 2" sumps woudl not fit. The outllets are -12AN.The block is a Dart Big M with Billet Caps 4.6 bore 10.2 deck.Rear end is CA Chassis Works Fab 9 (good for some mega power). I am ordering 40 spline Strange gun drilled axles next week and a Littlefield 14-71 blower to top it all off... Things are starting to get fun now! Attached ImagesLast edited by carnut68; 04-11-2009 at 10:37 PM.
Reply:OOOOYeah!!!!MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:I'd drive it.Once and only once!!!! That many pony's under a hood with doors that actually open & close, scares the peewaddin outta me.Where's the ejection seat?MarkI haven't always been a nurse........Craftsman 12"x36" LatheEnco G-30B MillHobart Handler 175Lincoln WeldandPower 225 AC/DC G-7 CV/CCAdd a Foot Pedal to a Harbor Freight Chicago Electric 165A DC TIG PapaLion's Gate Build
Reply:Nice second round of pics car nut, I notice you got the motor moved back also. All the fab work looks excellent.Shake and Bake
Reply:Nice work, I'm doing the same up here, to my chevelle.Last edited by 71metbu; 04-13-2009 at 02:37 AM.
Reply:Thought I recognized these pics from over on YB!If you're going to mount using bottom tabs only, I'd advise using a broader, two bolt brace on the seat back to disperse the load some. Even with the use of large washers on the bottom, those bolts want to rip out of the seat bottom on forward impact. That's why you'll see most of the "pro" cars bend a guide rod to follow the sides of the seat and secure it through the side, especially on the carbon fiber/composite seats. Car looks great though, planning on 25.2'ing either my existing wagon or picking up a fresh car to cut up. It'll be a cold day in Hell before I even think about going 7.50's, but it just might save my *** if I run that 26x8.5 tire class! Nothing like throwing 4 digit power at a set of lawnmower tires
Reply:Originally Posted by SupeThought I recognized these pics from over on YB!If you're going to mount using bottom tabs only, I'd advise using a broader, two bolt brace on the seat back to disperse the load some. Even with the use of large washers on the bottom, those bolts want to rip out of the seat bottom on forward impact. That's why you'll see most of the "pro" cars bend a guide rod to follow the sides of the seat and secure it through the side, especially on the carbon fiber/composite seats. Car looks great though, planning on 25.2'ing either my existing wagon or picking up a fresh car to cut up. It'll be a cold day in Hell before I even think about going 7.50's, but it just might save my *** if I run that 26x8.5 tire class! Nothing like throwing 4 digit power at a set of lawnmower tires
Reply:I saw that on the bullet !!
Reply:Originally Posted by carnut68Hey Supe,What's your name on YB?As for the back of the seat, the rules state there has to be at least one bolt in the back of the seat and 4 in the bottom. I plan in making two braces on the back, one behind the head and one behind the upper back for support using two bolts in each area for strength.Basically I am going to take some tube off the frame to some flat stock and bolt the seat to that. I will post photos of them when I get it done. Couple weeks away yet. |
