查看: 13|回复: 0
MIG welds on Dad´s grill
发表于 2021-9-1 00:11:02 | 显示全部楼层 |阅读模式
Here are some welds on my new dads grill...They were done using .035 wire on 14 ga square tubing and plate, both grinded with a flapper wheel and cleaned of grease with thinner...Voltage at C and wire speed at 3, straight CO2 at about 20 cfh on a PROMIG 175Don´t know why they have some kind of contamination, wether its that is mig outside, maybe too hot?, wire had a little bit of oxidation, cleanliness cause of the thinner?, or scale? Best pics shown...as soon as it stops raining i´ll take some pics of the complete grill Attached ImagesLast edited by elvergon; 03-25-2007 at 05:56 AM.My Babies: HF Drill pressHF Pipe Bender3   4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it!
Reply:2............. Attached ImagesMy Babies: HF Drill pressHF Pipe Bender3   4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it!
Reply:3....................... Attached ImagesMy Babies: HF Drill pressHF Pipe Bender3   4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it!
Reply:4.................. Attached ImagesMy Babies: HF Drill pressHF Pipe Bender3   4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it!
Reply:Dont look bad at all to me.. How big is this thing?Maybe just a touch more heat..and go a little slower..??So the bead isn't so spaced out.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Originally Posted by elvergonHere are some welds on my new dads grill...
Reply:Originally Posted by KRSWhat happened to your old dad???
Reply:He´s still the same but he will be in a new life when this grill is ready =)Ok got the advices Zap, and I´ll take measurements for you tomorrowThanks for lookingMy Babies: HF Drill pressHF Pipe Bender3   4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it!
Reply:UPDATEE: Here it is the base for the grill...its rusty I know, but its 14 ga??  I really don´t care for the rust right now when I polish it I´ll try to take some metal off for reducing some weight...Well this is the base... Attached ImagesMy Babies: HF Drill pressHF Pipe Bender3   4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it!
Reply:This is the charcoal box... The "ears" for lifting it are still waiting to be done... and some front and back plate too so charcoal won´t fall to the bottom of the grill...Hopefully it´ll last long  Attached ImagesMy Babies: HF Drill pressHF Pipe Bender3   4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it!
Reply:I´m liking the orange color lmao...nothing a good grinder can´t work...front part...this one you can open it so you can move the charcoal, place the onions etc... Attached ImagesMy Babies: HF Drill pressHF Pipe Bender3   4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it!
Reply:Here it is open...I like the size of this grill =) sometimes we´ve got so many people to cook for... Attached ImagesMy Babies: HF Drill pressHF Pipe Bender3   4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it!
Reply:Another view....you can see in the right the "donor" and old grill, I cut some plate from it for the charcoal basket... Attached ImagesMy Babies: HF Drill pressHF Pipe Bender3   4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it!
Reply:Another shot...wide open... Attached ImagesMy Babies: HF Drill pressHF Pipe Bender3   4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it!
Reply:Since this is welding web, here are some welds....I think the camera won´t be of much help :S Attached ImagesMy Babies: HF Drill pressHF Pipe Bender3   4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it!
Reply:Elvergon,Por favor, you quiero tacos de carne asada, cebolla verde y limon. Y una cerveza mas fria tambien. Pero, que no tienen, you quiero tacos de ceviche. No megusto tacos de tripe.  bueno,habla con usted en la mananajokerLincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:Originally Posted by Joker11Elvergon,Por favor, you quiero tacos de carne asada, cebolla verde y limon. Y una cerveza mas fria tambien. Pero, que no tienen, you quiero tacos de ceviche. No megusto tacos de tripe.  bueno,habla con usted en la mananajoker
Reply:I made my wife translate for me, she doesn't know "ceviche" or "tripe" any help?  -Cory
Reply:Originally Posted by g33kI made my wife translate for me, she doesn't know "ceviche" or "tripe" any help?  -Cory
Reply:Elvergon, are you welding those in an upward progression?  It looked like that in a couple pics.  If you are,  On material that thin you might have a smoother weld  if you adjust your settings and weld down hand.  Anything with any thickness i go up, but on sheet metal downhill will be easier and produce a smoother weld.  Just a thought.  Keep the pics coming.I'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
Reply:Originally Posted by Hammack_WeldingElvergon, are you welding those in an upward progression?  It looked like that in a couple pics.  If you are,  On material that thin you might have a smoother weld  if you adjust your settings and weld down hand.  Anything with any thickness i go up, but on sheet metal downhill will be easier and produce a smoother weld.  Just a thought.  Keep the pics coming.
Reply:By golly, you're getting it done elvergon. Good work.
Reply:MicroZone,Ceviche can be made a variety of ways with just as many ingredients. The best ceviche I ever had was made out of Stingray meat. It's almost like a salsa with meat in it. Lots of fresh diced veggies, chile and lime juice or lemon juice. You just slop it up into a hot corn tortilla fresh off the grill and oh my god, you can eat a dozen before you realize how much you ate!Toss in a shot of agave tequila and an ice cold beer of your choice buddy and you got good times.Elvergon, don't tempt me. My dad is very familiar with Monterrey and can take me right to your location! I might have to come down there and drop some beads on your barbecue!heheheBest wishesJokerLincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:Originally Posted by Joker11MicroZone,Ceviche can be made a variety of ways with just as many ingredients. The best ceviche I ever had was made out of Stingray meat. It's almost like a salsa with meat in it. Lots of fresh diced veggies, chile and lime juice or lemon juice. You just slop it up into a hot corn tortilla fresh off the grill and oh my god, you can eat a dozen before you realize how much you ate!Toss in a shot of agave tequila and an ice cold beer of your choice buddy and you got good times.Elvergon, don't tempt me. My dad is very familiar with Monterrey and can take me right to your location! I might have to come down there and drop some beads on your barbecue!heheheBest wishesJoker
Reply:I already filled out my passport application. I need to get my picture taken and pay the fee. I will be waiting for my passport before summer ends. We will see if I can make this year or next!PM me your address. I will talk to my dad and see if he is up for a trip to party.JokerLincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brainA wire wheel will make short work of that rust!   Lookin good!  My passport expired awhile back...I should probably look into getting that renewed...I mean, the new picture for it won't look much worse than what's in my welding logbook methinks!  Last edited by mb_welder; 06-06-2007 at 02:27 AM.
Reply:elvergon -mate thats a good looking grill it sure will be sturdy, good work , would like to see the final resultaustralian welding kid - i can fix it for ya  sure its gonna cost
Reply:Originally Posted by MicroZoneTripe - a type of edible offal made from the stomach of various domestic animals
Reply:Originally Posted by sam -ozelvergon -mate thats a good looking grill it sure will be sturdy, good work , would like to see the final result
Reply:elvergon , we have a lincoln sp170 here for small dia wires , we just welded up a bracket that is directly on the back of the welder and feels through a hole into the wire feed it works really good mate , but you could fab up a stand like you say. just giving you another idea of designaustralian welding kid - i can fix it for ya  sure its gonna cost
GMT+8, 2025-12-23 10:49 , Processed in 0.092297 second(s), 18 queries .
