Fast-freezing slag and back whipping
发表于 2021-9-1 00:11:02 | 显示全部楼层 |阅读模式
I just read this article:http://www.thefabricator.com/ArcWeld...cle.cfm?ID=671and it talks about making the "stack-o-dimes" look with 6010 type stick electrodes(i do this all the time with hard wire  for steel and aluminum). now here is my question is i use a fast-freezing dual shield fcaw welding wire. has anyone ever tried this? and what are the pros and cons?
Reply:Thanks, I just printed that and will read it tonight.  I don't think you can whip cored wire.  stick out would not be consistant which would throw amps all over the place.  Some might even escape   DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:I read the article last night.   I DO whip bare wire all the time (circular).  I don't know about doing it with flux core.  I have some and will try it later.David
GMT+8, 2025-12-23 10:45 , Processed in 0.090414 second(s), 19 queries .
