Gas pressure
发表于 2021-9-1 00:11:02 | 显示全部楼层 |阅读模式
Got the HH187 up and running the other day. What a sweeeet machine!  When I am done, I turn the tank valve off.  This leaves the line between the regulator and gas valve in the machine pressurized.  Is this okay, or should I release the wire tension and basically trigger a "purge" to relieve the pressure?
Reply:I see no reason not to leave the line pressurized.  What's it going to hurt?  One thing it will do for you, is show if the system has any leaks, cause if you leave it pressurized, but find it is not pressurized later, you have a leak.
GMT+8, 2025-12-23 10:46 , Processed in 0.089613 second(s), 18 queries .
