Keep cool as it heats up--Hanging Fans
发表于 2021-9-1 00:10:59 | 显示全部楼层 |阅读模式
In about thirty days it will be hotter than the face of the sun in my garage.  I can easily reach 110 degrees inside. Lucky, I have it insulated and Air Conditioned . However, on some days like about now, when its 80 plus or minus, moving a bit of air around can make all the difference. So, I have hung these fans at strategic locations around the shop so they are not in the way, and they blow down on you.  There are only a couple of welds on the plate that holds the 1 inch square tubing to the ceiling and the plate that the fan bolts to.  There is a 1/2 bolt with a nut welded inside the tubing that allows the fan to hold tight to the plate and rotate.  They be easily reached to turn up, down, rotated, or off. I got the fans at Home Depot, Honeywell Brand, I think they were about twelve bucks or so. Thought this might be of interest as things heat up.
Reply:thats a cool idea. now i gotta get some fans lol
Reply:Pretty COOL ideaI see bigger things in your future Attached Images"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Oh Yeah! Wind Turbines! Let me at'um........
Reply:That little fan must be mite powerful. In the second picture it's sucked a bicycle into its intake.
GMT+8, 2025-12-23 10:44 , Processed in 0.114043 second(s), 18 queries .
