stacking dimes using FLUX
发表于 2021-9-1 00:10:57 | 显示全部楼层 |阅读模式
Can you weld over a cooling weld using fluxcore wire? Does the flux settle only when it cools, or are you welding on the flux?
Reply:Originally Posted by Mighty MouseCan you weld over a cooling weld using fluxcore wire? Does the flux settle only when it cools, or are you welding on the flux?
GMT+8, 2025-12-23 10:58 , Processed in 0.103764 second(s), 19 queries .
