New Trailer Hitch
发表于 2021-9-1 00:10:55 | 显示全部楼层 |阅读模式
My hitch rotted out so I called the local vendor for a new one, 10,000 lbs, out of stock and $495. so I built this one from 3/8 steel. Better than I could buy but It took the better part of the day. Attached Images"Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:Looks Very Good Kolot.
Reply:Me and My Dad fixed a hitch today. Well.. the whole dang bumper on a dodge service truck. His Bosses
Reply:Not bad... I make quite a few custom hitches thoughout the year.. 495?  I'm going to have to charge more.Common sense in an uncommon degree is what the world calls wisdom.
Reply:Very cool indeed!  Isn't it great having these skills!!!!!!  Makes my friends so jealous.
Reply:Great job.  Probably stronger than the "store bought" one you replaced.  $495?  Wow.  Do you have a Redneck Trailer near you?  I buy all my trailer hitches, brake controllers, light kits, etc from them.  Have just about anything you need for a trailer, plus parts for repair.  Here's a link to their site:http://www.redneck-trailer.com/
Reply:Originally Posted by paweldorGreat job.  Probably stronger than the "store bought" one you replaced.  $495?  Wow.  Do you have a Redneck Trailer near you?  I buy all my trailer hitches, brake controllers, light kits, etc from them.  Have just about anything you need for a trailer, plus parts for repair.  Here's a link to their site:http://www.redneck-trailer.com/
Reply:Nice work on the hitch kolot,what size and grade of bolts will you use to install it?Lincoln 225 ACLincoln Mig Pak 15Lincoln Mig Pak 10Purox Oxy-Acet Outfit20 Ton PressHonda Generator
Reply:Painted and installed yesterday afternoon, Grade 8 , 1/2"-20 fine thread , lock washer and nuts grade 8 also torqued to 120 Ft LB.  Store hitch in question was "The Beast" from Draw Tite  2 1/2 tube with 1/4 frame plates.  2WKs special order, Mine is 3" tube with 3/8 frame plate. I didn't realize it but my old hitch was tagged 10,000 load distributing and 5,000 regular. so between that and being rotted I was way overloaded."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:Got a picture with it all painted up and installed?
Reply:Very tough looking! 3" tube, eh? You gonna make you a ball mount to match the 3" tube now? City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:Looks like a good job. Guarantee you it's a lot better made and stronger than a $495. one!Only when the last tree has died and the last river has been poisoned and the last fish has been caught will we realize we cannot eat money.                                         -Cree Indian ProverbSA 200 LincolnVictor Torches
Reply:3 inch tube on the main cross member, regular store bought 12" lower reciever to fit the ball hitches and pintles, I by them 3 at a time from a local truck body installer/builder. I use those recievers for alot of things. Seems guys always want detachable racks on their trucks and trailers and these work good and also can be pin locked."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:I've thought about mounting another reciever hitch on the side of the bumper for a vise.
Reply:Originally Posted by kolotMy hitch rotted out so I called the local vendor for a new one, 10,000 lbs, out of stock and $495. so I built this one from 3/8 steel. Better than I could buy but It took the better part of the day.
Reply:Nice Job man,That thing is very serious looking....  I imagine it will last a VERY long time.  What did you use to prep and paint to avoid it rusting again ?Cheers,/Jman...
Reply:I didn't do any fancy prep and paint, just restoleum primer and paint for now. The truck frame has gotten so scaley I promised myself I would tear it completely apart this summer and do it right. Have to remove all the lines , fuel tanks, even axle and spring hangers, If I don't I will loose it. Thought about looking into some sort of marine boat coatings, anyone have any experience or ideas?"Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:"The Better Part of a Day" is usually taken up by the time to sit, look, and figure out what you want  Seems that when you know it's right, it doesn't take too much time to actually do the work.  One of a kind stuff is always that way it seems"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Originally Posted by kolotI didn't do any fancy prep and paint, just restoleum primer and paint for now. The truck frame has gotten so scaley I promised myself I would tear it completely apart this summer and do it right. Have to remove all the lines , fuel tanks, even axle and spring hangers, If I don't I will loose it. Thought about looking into some sort of marine boat coatings, anyone have any experience or ideas?
Reply:hey try that roll on bed liner we use that stuff on all the trucks and even on the bottoms of the jeeps it works well and is only 20 dollars for a 1 gallon can and pep boys and o'rialley have them all automotive places have it if you really wanted to have them linex it you could go muddin and still just wash it all off but that is the expencive option later agwelderold skool idealarc welderEsab multi tool Milwauake 7inch angle grinder the best of all tho the oxyacceteline set up
GMT+8, 2025-12-25 09:41 , Processed in 0.091409 second(s), 18 queries .
