White picket fence with a twist
发表于 2021-9-1 00:10:53 | 显示全部楼层 |阅读模式
Been building up a lot of pricey parts for my chopper project,so I'm improving security  Attached ImagesVictor SuperRanger O/A                                         Solar migLincoln Powermig 140Southbend 9in lathe350# kohlswa anvilMiller Maxstar 150 stl etc....
Reply:I had some 1/2sq rod 41 inches long that i forged a point on and shaped over my anvil  .Then i forged points on some 3/8rd bar and shaped and cut to size. Using a magnet and vise grips i tigged the points on the sq bar.Last edited by David R; 11-11-2007 at 07:37 AM.Reason: Fixed picturesVictor SuperRanger O/A                                         Solar migLincoln Powermig 140Southbend 9in lathe350# kohlswa anvilMiller Maxstar 150 stl etc....
Reply:Then i spaced them 6in apart and stick welded them to some 3by3 angle.I had a lot of trouble with the 6013 rod. It was rusty and didnt seem to be running good   Attached ImagesVictor SuperRanger O/A                                         Solar migLincoln Powermig 140Southbend 9in lathe350# kohlswa anvilMiller Maxstar 150 stl etc....
Reply:All together its about 6ft in the air,you could get over it. just dont slip  Attached ImagesVictor SuperRanger O/A                                         Solar migLincoln Powermig 140Southbend 9in lathe350# kohlswa anvilMiller Maxstar 150 stl etc....
Reply:Good thing you don't live in California. You would get sued for potential injury.Lincoln PowerMIG 215XTLincoln Precision TIG 225Hypertherm 300
Reply:That thing is wicked cool.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:nice job clark-kentski I like that alot  if someone is dumb enough to try and get over it and gets caught up on it to bad for them they only have to look at it and think this could hurt lots  Creative metal Creative metal Facebook
Reply:Looks very nice all you need now, is tack on some foot holds lower down, as they stand on them they break off, impalling them on the spikes. lol
Reply:You put some time into it and it shows.  Nice jobDavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:Nice job ,i should think any one silly enough to try and climb it and slip,would make there eyes water.
Reply:Originally Posted by clark-kentskiBeen building up a lot of pricey parts for my chopper project,so I'm improving security
Reply:I use a one burner, propane fueled farriers forge to heat the metal to an orange heat then twist.The same could be done with oxy-acet using a rosebud tip Victor SuperRanger O/A                                         Solar migLincoln Powermig 140Southbend 9in lathe350# kohlswa anvilMiller Maxstar 150 stl etc....
Reply:Originally Posted by clark-kentskiI use a one burner, propane fueled farriers forge to heat the metal to an orange heat then twist.The same could be done with oxy-acet using a rosebud tip
Reply:Originally Posted by Twisted MinisGood thing you don't live in California. You would get sued for potential injury.
Reply:cool,,dangerous but Cool
Reply:Should change the tile from "white picket fence" to "white stickit fence"Be nice to have a shorter version around my yard to keep all of the dogs from crapping on my lawn.Nice job.
Reply:How about:  "Wicked White Picket?"
Reply:Originally Posted by jdh239Be nice to have a shorter version around my yard to keep all of the dogs from crapping on my lawn.
Reply:Originally Posted by SpyGuyI'd settle for having one of these to keep the javalinas and coyotes off my back patio ..........
Reply:In Florida, you wait for them to impale themselves on it, then you shoot them.
Reply:Originally Posted by azlarCoyotes woulds probably still jump it. To keep the javies out you need something akin to the border fence
Reply:If I did that here in Detroit, and someone got snaged in it, I'd be sued into the poor house. just a week or so ago some guy broke into someones house, got bit by the dog, now the guy is suing the home owner, and the sad part is that he will probably win.If I Can't Weld It!-----It Can't Be Welded!
Reply:Is this really the case:Good thing you don't live in California. You would get sued for potential injury.
Reply:I personaly think that when you are commiting a crime you should forfit your right to sue. JMO  and yes in Cali you get sued over stupid stuff like that.[SIGPIC][/SIGPIC]weekend metal melter and all around pain
Reply:I agree that if you are committing a crime that you lose your rights. Thats what is wrong with our judicial system, the criminal has more rights than the victim. Just like the lady that sued McDonald's over the hot coffee that she spilled in her lap. The Judge should have told McDonald's to lower the temp, and made the lady wear a sign stating not to give her coffee because she didn't know HOT coffee was supposed to be hot regardless as to how hot it actually was. We suffer because of BS court cases like this and these cases waste time that should be devoted to real judicial business.Sorry for the rant but this BS burns my butt.Originally Posted by scott brunsdonIs this really the case:Just curious.(Great looking fence, too.)Scott
Reply:Originally Posted by scott brunsdonIs this really the case:Just curious.(Great looking fence, too.)Scott
Reply:I think the topmost 6013 weld looks allright.The one lower down is a little cold.  I imagine you kept cranking the amps up until you got an acceptable bead.  It's sometimes a PITA when joining a thicker to a thinner section.  The thick section acts like a heat sink, and chills your weld.The thickness you welded should run at around 135amps.  Even at the higher amps, 6013 seems to have a tendancy to pile up and make a convex bead.  Doesn't make it a bad weld though.MEAN LOOKIN' BARRIER"Any day above ground is a good day"http://www.farmersamm.com/
GMT+8, 2025-12-25 09:40 , Processed in 0.069567 second(s), 18 queries .
