Look what i found!!!????
发表于 2021-9-1 00:10:52 | 显示全部楼层 |阅读模式
Man i am nuts!!! I found this on craigslist. Not sure what it is worth. The guy is asking 450.00. He is nuts!!!. What should i offer him.  I don't have the time to mess with it, but would be a fun project to just dick around with. Any ideas by looking at the picture what year it is and how much it is worth.ThanksAaron
Reply:Judging from the background it com be Farmer Samm's place.
Reply:You could try the value in scrap minus drive time.Common sense in an uncommon degree is what the world calls wisdom.
Reply:Not a Shorthood and has large fuel cap so is younger than 1956.Vacuum idler and front panel lead connections so is older than early 1972.Looks to be a faded Redface so likely is older than 1970.Probably the best guess until you get the serial and codeGordie -- "I believe you understand what you think I said, but I'm not sure you realize that what you heard is not what I meant."
Reply:Did the engine throw a rod, or have water collect in the exhaust? Are the bearings gone from no oil? Even if it 'runs', it might have major problems. Same with the rest; have rodents chewed the wires and their urine corroded things?You'd really need to check it closely to determine the condition before guessing at a value. What do you 'need' it for? Sometimes just to play with is justification, othertimes it must perform as new; only you can decide.
Reply:We are all nuts!!!Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:A shame is what I call it.....a fine peice of equipmet like that sitting in the mud.....shame shame shame ..that machine proly has some stories to tell that would blow someones mind...well i would like to think that.and I am only 99.7% nutsIf it's too . get an office jobLincoln wp225g7 Lincoln 250 idealarcFrankenstein O/A set-up Weld-tech  tig set-upLincoln sp 175 plus profax  arc gouger
Reply:Make him pay you to remove it.Kevin's Welding Service.Miller Bobcat 250.Millermatic 212.Hypertherm Powermax 600.Victor Journeyman torch set.Speedglas 9000XL
Reply:I paid $650 for mine. It was about the same condition. I will bet the engine is frozen and the plugs are off and it is full or rain water.  The overhaul kit without the oil pump, carb, plugs and wires cost more than I paid for it. Check out my rebuild link and see what you are getting yourself into.http://weldingweb.com/vbb/showthread.php?t=20768The best part is that it can be restored. You can make your money back in selling it for parts.My Gear is:Two Miller Thunderbolt 225Millermatic 211Miller Spectrum 875 PlasmaMiller Spot WelderLincoln SA-200
Reply:If its frozen up order some stuff called mouse milk will have to get it from an aircraft supply. It devolves rust like you would not imagine. We use it when restoring old tractors. Works wonders just need to be careful will eat certain things up.
GMT+8, 2025-12-25 09:41 , Processed in 0.064559 second(s), 18 queries .
