Aluminum iguana cage
发表于 2021-9-1 00:10:52 | 显示全部楼层 |阅读模式
This is an cage that I made for my iguana. It is made of 1/4" aluminum round stock and 3/16" Aluminum plate,formed that i welded with a spool gun. The iguana heads were cut on a water jet. The bottom has a steel tray riveted to an Aluminum face with a handle welded on it that pulls out for easier cleaning. The cage stands 5'-4"x30"x36. I think it turmed out pretty good. Any comments would be great. Thank you. Attached ImagesGo hot, or go home!
Reply:very nice, that could be good for a parrot too.
Reply:Now that's pretty slickMust have driven you nuts to keep all the bars aligned, then making all the welds.Good simple cheap hinges.  Fit the bill, and work."Any day above ground is a good day"http://www.farmersamm.com/
Reply:Complete with tow hitch"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Originally Posted by farmersammNow that's pretty slickMust have driven you nuts to keep all the bars aligned, then making all the welds.Good simple cheap hinges.  Fit the bill, and work.
Reply:Very nice work. Now for an off the wall ? Does your iquana have a name ?
Reply:I put the side together first, I used a 1"x1" sq. tubing as a spacer for tacking up the round stock. that way, I knew that each bar would be perfect. The hardest part was keeping the door square and flat while welding it. I really jumped around and took some time to control the heat input. And yes the iguana has a name, Agave. I love tequila! Thanks for the posts guys. This is a great site!Go hot, or go home!
Reply:Great job on the cage. There must be quite a bit of time in design and working out the kinks.  Pretty lucky critter.I dont think a big bird in an aluminum cage would be a good idea... My friend breeds exotic birds and they damage steel cages all the time with just their beaks.Common sense in an uncommon degree is what the world calls wisdom.
Reply:Aluminum Oxides make their little feet turn funny colors too Attached Images"Any day above ground is a good day"http://www.farmersamm.com/
Reply:better truth test that one on wikipediaIt's raining and I'm bored"Any day above ground is a good day"http://www.farmersamm.com/
Reply:I actually only have about 16 hours into it. I kinda skipped the design process and jumped right into the build. I built it to burn up the last few days of school at Fox Valley Tech, before our year was up.Go hot, or go home!
Reply:Originally Posted by El_Lloydeovery nice, that could be good for a parrot too.
Reply:good looking cage. last cage i built for an animal i made or of glass and wood. looks like you put some pride into yours. good on yaIf you like my stuff you can find me on Facebook.  https://www.facebook.com/theangryanv...ngryanvilforge
Reply:Hey, DeucedJ22;Since you like Igs and probably other similar critters, you might like to take a look at this site:http://www.baars.org/" target="_blank">http://www.baars.org/.
GMT+8, 2025-12-25 09:40 , Processed in 0.092200 second(s), 18 queries .
