need help pricing a water cooled TIG torch??
发表于 2021-9-1 00:10:51 | 显示全部楼层 |阅读模式
i have a HW-18 torch and cables i need to get rid of. but not shore what kind of price to ask when i list in my e-bay store. or if some one here needs one feel free to contact me. its labled as a genuine HELIARC on the handle along with its WH-18 stamped in the torch head. wile i dont know the age of it i do know its not been used and is a 25' 3 tube cable system. its also marked as esab welding and cutting products and thease #'s A348 and 52350so its all original and was ment to be togather.i needed it to make shore when i was making my watter cooler i got all the hookups right but as its a 350amp setup and the most my TIG can do is 185 its a bit much for my useages. heck i could probly run it with no water at my amps. (no i havent done so, just a joke) so when i get my cooler built (if i ever do ) i will need a smaller one any way. this one seems about the same size or maybe a lil bigger then my wp-17. again too much torch for me but i shore like the 25' reach idea.any way i looked around on the net a lil bit and found them from $150 to $270 but not real shore what all comes with the ones listed or what should be with this one??? so any help would be great on pinning down a fair sale price, or an offer to give it a new home. i will answer any questions i can about it and take more pic's if you all want or need them. i just had this pic from when i made the spare torch case to put on my site (still havent done that eather, man i'll falling behind)thanks guys. Attached Images summer is here, plant a tree for mother earth. if you dont have time or space, sponcer some one else to plant one for you.feel free to shoot me a PM or e-mail me at [email][email protected] i got lots of time.
Reply:Can it hook up to a lincoln invertec 205?? If so, I am your guy. Paul.
Reply:Does it take the same parts as  your PT17?  collets, gas cups.....DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:Rojodiabloif you have a water cooler yes it will hook up it will use standerd water flow threw dyns conector or a power block if you chose to go that rought.but i think the WH-20 ( http://store.cyberweld.com/db250ampwatt.html )would be a better fit for your welder as its a 250 amp torch and the welder you have is only 205amp.the one i have is a 350amp torch. so if you want water cooled to go smaller the 20 would be the way to go, if the size is ok mine would work and alow you to go water cooled but again the WH-20 would be a smaller torch. so it depends on why you are going water cooled i guess. i wanted to go water cooled for a smaller torch, well that and just to have it. good excuse to build a cooler.David Ri dont know if it uses the same parts as the my 17 dose ? i never used it or tryed to see if the 2 interchange guts, looks similer in size but i would check with arc-zone they are prity good at answering questions on aplications and parts needed. from checking replacement collet bodies on the cyber weld site the WH18 and the WP-17 both call for the same pat the 10N collet bodie so it looks like they use the same parts. i guess thats why the looked about the same size LOL.i'm prity new to TIG still so i'm not all that up on all the diferent options available. thats why i started this thred. i was hopeing some one with some more info about the torch could help me establish a fair price. if some one on here is interested in it i will make them a lil better deal on it as i like to help out the guys here whenever posible. so whatever i end up listing it for i'll knock off a few bucks, or throw in the case, or free shipping, or some thing along those lines.here is a closeup of the handle with the heliarc sticker. Attached ImagesLast edited by fun4now.; 04-06-2007 at 12:59 AM. summer is here, plant a tree for mother earth. if you dont have time or space, sponcer some one else to plant one for you.feel free to shoot me a PM or e-mail me at [email][email protected] i got lots of time.
GMT+8, 2025-12-25 09:49 , Processed in 0.068145 second(s), 18 queries .
