Another MIG weld
发表于 2021-9-1 00:10:51 | 显示全部楼层 |阅读模式
More from class, butt weld 3mm low carbon steel, 3 mill gap between the plates and a steel backing plate under. not bad eh? I need to grind the tacks out though.
Reply:Little excessive on the spatter but all in all......... doesn't seem bad_________________Chris
Reply:Pretty nice.  Why the backing plate I wonder?Various GrindersVictor Journeyman torch200cf Acet. 250cf oxygenLincoln 175 plus/alpha2 gunLincoln v205t tigLincoln 350mpEsab 650 plasmaWhen you can get up in the morning, Its a good day.Live each day like its your last.
Reply:looks as though you have some under cutting and the begining of your weld.I would start my weld apporox 1/8 -  and back step and then start the "pass".GEdit* If thats the end of the weld, I would suggest to finish weld then come back and do a little circle motion, it will help Fill it "all" in.Last edited by GURDEEPFULLPEN; 04-07-2007 at 12:50 AM.
GMT+8, 2025-12-25 09:40 , Processed in 0.094225 second(s), 18 queries .
