what tig welder does one suggest
发表于 2021-9-1 00:10:50 | 显示全部楼层 |阅读模式
I am in need of some advice... I am in the process of purchasing a tig machine...  majority of work will be light to medium fabrication on various metals; stainless, cro-moly, and Alum. with most applications involving metal thickness less than 3/16... however with occasional 1/4 inch.I am looking at Miller syncrowave 200 and dynasty 200 DX... now for the question, how important are the extra features with dynasty. I have little experience welding Alum however this will change once I have my own machine; repairing / building bicycle frames, T-Top for fishing boat etc...Will need a machine to also weld really thin SS... with low amps ~5 or less.what machine will best suit needs mentioned?  Please mention other machines if a different will work beter...Any advice will be welcomed.Last edited by moonlitewelder; 04-07-2007 at 05:21 PM.
Reply:I went with the dynasty for a couple reasons...  Availability of power... strip the wires and stuff in the box - chances are it'll run on it. ( 1 or 3 phase, 110 - 440v).  Range of current out.  I wanted to be able to do sheet metal.  I'd have gotten the maxstar, but wanted to learn to do Alum... which needs a/c
Reply:You'll be happy with the Miller, good choice. Support and consumables are easy to get.John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Go with the dynasty 200dx, you will NOT be disappointed. I got one recently and put it through its paces this week. Welded some custom aluminum valve covers, .100 aluminum to 1/2" flanges. Off of 230v/20a power, the machine put out the full 200 amps and didn't seem to work too hard as the fan only came on periodically. The 1/2" did need a little pre-heating, but once the heat was in, ran like butter. Your 1/4" stuff should be cake. The pulse feature is real nice on that stuff too. Hope this helps.
Reply:thanks for the comments - well all three go for Miller and 2 for 2 support the dynasty 200dx. I was leaning that way but was on the fence regarding the extra grand for this machine. do love the portability aspect of it as well.thanks again.
Reply:LINCOLN!! heh... THERMAL ARC!!! Really, they seem to all have there plus and minuses.  Everyone loves the one they got it seems (think cause its theirs  )Various GrindersVictor Journeyman torch200cf Acet. 250cf oxygenLincoln 175 plus/alpha2 gunLincoln v205t tigLincoln 350mpEsab 650 plasmaWhen you can get up in the morning, Its a good day.Live each day like its your last.
GMT+8, 2025-12-25 09:41 , Processed in 0.088402 second(s), 18 queries .
