Is it important to put in a .024 liner when I run .024 wire?
发表于 2021-9-1 00:10:47 | 显示全部楼层 |阅读模式
I'm going to be welding with .024 solid steel wire, but my M-100 gun has the standard .030/.035 liner in it.  Is it necessary to install a .024 liner before I run .024 wire?  Or can I just use the existing liner? The existing liner is in good shape.Thanks!KenMilermatic 211
Reply:Today I read on this very same forum that as long as the wire is of the same size or smaller than the wire liner, you should be ok.I hope that helps,Mikel
Reply:I run .024 through my ,030 liner all the time, no problem, just use the right .024 tip...miller 330a bp TIGmiller dynasty 200DX TIGmillermatic 185 MIGthermal dynamics cutmaster 101 plasma cuttersnap-on YA5550 plasma cutterhypertherm powermax 30 plasma cutterbaileigh CS225 cold sawetc....
Reply:Originally Posted by turbocad6I run .024 through my ,030 liner all the time, no problem, just use the right .024 tip...
Reply:You guys that worry about the liner can keep paying for them, I have a 1/16" liner in both guns on my feeders and run from .030 to 1/16" with out a hitch.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
GMT+8, 2025-12-25 09:40 , Processed in 0.136180 second(s), 18 queries .
