Farm machinery repair
发表于 2021-9-1 00:10:40 | 显示全部楼层 |阅读模式
This is off of a Mulch Finisher, didn't get a picture of the whole machine, maybe I can find a picture.They were turning when the outside set of lift wheels dropped in a washout, the pictures tell the rest. Got them fixed up so they could get back in the field and has been raining ever since.Found a picture of a similar machine. Attached ImagesTrailblazer 302Hobart Stickmate AC/DCLincoln SP 135 TSmith torchSpoolmatic 30A
Reply:Yep,Seen and made that repair a time or two...Harrow axles are always fun...Next time,  I would suggest that you add a T brace, gusset or something to reinforce the part.  What happended before can happen again.  My idea would be to prevent it from ever happening again if it fell into a canyon while it was turning.Got the completed pics?Last edited by lugweld; 04-28-2009 at 12:11 PM.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Looks good to goPretty pricey lookin' green machineThey don't build stuff like they used to."Any day above ground is a good day"http://www.farmersamm.com/
Reply:How much horsepower to pull that thing??Last edited by farmersamm; 04-28-2009 at 07:21 PM.Reason: spelling"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Originally Posted by farmersammHow much horsepower to pull that thing??
Reply:What's really amazing are some of the old photographs of large fields being worked by up to 4 tractors in a staggered line.  Each one probably pulling a 10' implement.I've seen old photos of the same thing when plowing.  Each tractor maybe pulling a 4-16 plow.Amazing how far we've comeLast edited by farmersamm; 04-28-2009 at 08:35 PM.Reason: double specs, have to understand it to see it.  LOL"Any day above ground is a good day"http://www.farmersamm.com/
Reply:I'm still in the stone age, as you'll see with the latest project started today"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Originally Posted by lugweldYep,Seen and made that repair a time or two...Harrow axles are always fun...Next time,  I would suggest that you add a T brace, gusset or something to reinforce the part.  What happended before can happen again.  My idea would be to prevent it from ever happening again if it fell into a canyon while it was turning.Got the completed pics?
Reply:Shortarc, Looks like you were working onsite with your portable rig. I am interested in your portable vise setup. Plugged into your trailer hitch/receiver?Stew
Reply:What did you cut that steel with?Last edited by slagmatic; 05-03-2009 at 11:18 PM.
Reply:Originally Posted by cranestShortarc, Looks like you were working onsite with your portable rig. I am interested in your portable vise setup. Plugged into your trailer hitch/receiver?Stew
Reply:Originally Posted by slagmaticWhat did you cut that steel with?
GMT+8, 2025-12-23 09:16 , Processed in 0.067821 second(s), 18 queries .
