Yet another Mig/Plasma Cart
发表于 2021-9-1 00:10:39 | 显示全部楼层 |阅读模式
I am a beginner and it has been over three years since taking a welding class (with not much chance for welding since then) but I finally took the time to make a stand for my Mig and Plasma Cutter. No welds to show but suffice it to say, some were good and others got ground out and redone. Still a couple of minor things to finish (air line to Plasma and Tank strap rather than a bunge cord). All in all, it was a fun thing to do, practical to use, and gave me an excuse to try out a cad program. Not fancy but perhaps others may see some idea that would be of use. Thanks to all for the tremendous number of ideas that others have contributed on this forum. Attached Images
Reply:I don't see anything wrong with that at all. Good job.  If you get a bigger tank you might have to move the MIG forward.
Reply:great job
Reply:Welcome to the forum tmac  and thanks for the thread.  Great job  and I love the color! MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Nice!  Well planned, good design.But what do you mean by saying you don't have any welds to show off?  How did you stick all those pieces of metal together?  Elmer's Glue-all? J-B Weld Epoxy? Magnets? Keep up the good work!!  -MondoMember, AWSLincoln ProMIG 140Lincoln AC TombstoneCraftsman Lathe 12 x 24 c1935Atlas MFC Horizontal MillCraftsman Commercial Lathe 12 x 36 c1970- - - I'll just keep on keepin' on.
Reply:Wow, looks great, good job.Working on cars and bikes is my hobby, learning to weld the pieces together is my quest.
Reply:TMAC, I too made myself a cart after looking a quite a few here. The one thing I did not add and think I want to is, that piece of pipe on the right side to hold the handle when not in use. Now, after a time, how has that worked? Also, presume that is your RV in the photo? You build it?Stew
Reply:looks like the same settup i have. looks good. should work well for youIf you like my stuff you can find me on Facebook.  https://www.facebook.com/theangryanv...ngryanvilforge
Reply:Cranest, it works OK though I don't expect to use nearly as much as the one on the welding table. It provides a good alternative when I am next to the cart since the cables are only 10' long. Yes, I built the RV. It is RV9A that I finished in started on in 2001 and finished in 2004. It is a great airplane and has covered a lot of flying ground. Here is a link with some more pictures if you are interested: http://picasaweb.google.com/mcintoshtw/N369TM#
GMT+8, 2025-12-23 09:17 , Processed in 0.094184 second(s), 18 queries .
