Slopped up a folding weld table today
发表于 2021-9-1 00:10:38 | 显示全部楼层 |阅读模式
Put some scrap to use for small projects. Attached Images
Reply:Looks good.  I made one several years ago similar to that except I used expanded metal for weight savings.  I usually don't hammer on it so it works good for me.I also didn't think about the bar on the backside to hold the clamps.  Mine is light weight so I don't clamp much to it, except to keep the project from tipping over.MarkI haven't always been a nurse........Craftsman 12"x36" LatheEnco G-30B MillHobart Handler 175Lincoln WeldandPower 225 AC/DC G-7 CV/CCAdd a Foot Pedal to a Harbor Freight Chicago Electric 165A DC TIG PapaLion's Gate Build
Reply:Nice.  What's it weigh?
Reply:Nice job crashmcwhly. How does it lock in place when set up?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Originally Posted by Jack OlsenWhat's it weigh?
Reply:Originally Posted by duaneb55How does it lock in place when set up?
Reply:thats great looking. As you said must be nice to make it all dissappear when all done working.25 years of age.Been welding since Feb 23rd 2009.LU1007 Millwright (A1)
Reply:Originally Posted by crashmcwhlyI used 3/4" x 3" round stock as permanent hinges on the back side and 5/8" x 36" round stock to thread through the front legs and inside the square tubing.  When colapsed, you can see the 36" rod stored in the clamp bar.
Reply:Has all the aspects of an efficient design.  I need to make one of these to replace my plastic saw horse and sheet metal over plywood table...   I know, tell me about it!
Reply:Slick work, very nice.  Would certainly be a better setup than what I'm using (road sign over a folding typewriter table)
GMT+8, 2025-12-23 09:11 , Processed in 0.087964 second(s), 18 queries .
