new toy, positioner, first use
发表于 2021-9-1 00:10:21 | 显示全部楼层 |阅读模式
1:  ebay purchase. Naturally delivered damaged, bent shaft was in machine and new one I turned from bar stock. Corner of base casting broke. Wonder who could fix that? cast alu  2:  broken casting  3:  casting welded  4:  assembled machine  5:  First job, 5/8 nf nut welded to steel end plate for argon pump.casting   no preheat, bevel, TIG, AC, arogn, 3/32 red tung, 1/8 4043 filler, balance at 7, syncro 250nut/plate  DC TIG, 3/32 red, argon, 316 1/16 filler, .8 rpm, 170 amps, held torch and fed rod by hand
Reply:oops, here is pics Attached Images
Reply:Nice stuff.....Yer gonna love it!DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:I could use one like that.  What you pay for it if you don't mind?everything I want one for is small, like 8" in dia or less.  One like that would be great.
Reply:whats that thing forlincoln weld pac 100Hobart handler 120Lincoln  "BuZZ box"Lincoln Precision Tig 225
Reply:I have the exact same one..Word of advice..Do NOT run over 150..180 amps thru it..The ground strap inside can't take it..I just clamp the ground to the piece when needed.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Originally Posted by beamed94OneFiddYwhats that thing for
Reply:Nice tool! Too bad it needed repairs to get it goin'!Does the chuck mount to the base plate with the spring clips?Rex
Reply:Originally Posted by zapsterI have the exact same one..Word of advice..Do NOT run over 150..180 amps thru it..The ground strap inside can't take it..I just clamp the ground to the piece when needed.....zap!
Reply:Originally Posted by BoostinjdmI could use one like that.  What you pay for it if you don't mind?everything I want one for is small, like 8" in dia or less.  One like that would be great.
Reply:Thanks castweld for the link to the maker. Went and downloaded the manual for it. Thanks Red.Lincoln Percision tig 225 (Water cooled)Lincoln 350MP Power mig (with spool gun )Lincoln GXT 250 With Tig  ModuleLincoln Ln-25 Pro Dual PowerCentury 50 plasma cutter.now Lincoln .
GMT+8, 2025-12-23 09:10 , Processed in 0.114072 second(s), 18 queries .
