Welding a Bronze Rudder Shaft
发表于 2021-9-1 00:10:20 | 显示全部楼层 |阅读模式
I am making a new rudder shaft for my sailboat.  The shaft is 1" and it has a 1/4" piece of plate bronze welded to it over a 16" length.  What is the preferred method for making this crucial structural weld? I have been on the site for a short while...great forum!
Reply:Originally Posted by F40I am making a new rudder shaft for my sailboat.  The shaft is 1" and it has a 1/4" piece of plate bronze welded to it over a 16" length.  What is the preferred method for making this crucial structural weld? I have been on the site for a short while...great forum!
Reply:I met a guy at a boat show that tigged bronze propellers but he wouldn't tell me what filler, tungsten, machine settings or even the welder he was using, all he told me was he was using "a very good machine and it is a Miller".   Sorry that i could give more advice.CharlesThunderbolt AC/DCRed Flames BWELincoln sp-135t
Reply:Just to confirm this post is about welding bronze to bronze.  Can tig do this?
Reply:Originally Posted by F40Just to confirm this post is about welding bronze to bronze.  Can tig do this?
Reply:I've tigged bronze with A.C...like on aluminum..with with silicone bronze rod..Great results!...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:it can be done with tig i use a nibral filler  3/32--1/8
Reply:There are a few different types of Bronze alloys listed in Lincoln Electric's Arc Welding Handbook (Section 10).  The preferred method of welding, polarity, shielding gas (if applicable) and filler metal depends on what type of bronze the base metal is composed of.If you can provide more details on the material, I can let you know what is recommended.
Reply:Go to www.ampcometal.com. They have all the info you need as far as filler metal, and processes.-------------john
GMT+8, 2025-12-23 09:20 , Processed in 0.132149 second(s), 18 queries .
