Red versus Blue
发表于 2021-8-31 16:58:56 | 显示全部楼层 |阅读模式
Interested in the more experienced welders thoughts on 2 machines.The Lincoln Idealarc Tig 250/250 variable voltage AC/DC welding power source versus the Miller Model 330A-1BPLA.  Pound for pound and dollar for dollar how do they stack up against each other.  Consider both to be fully equiped.  Thank you for reading.
Reply:The Miller is more HD/commercial machine with more amps. You aren't comparing apples to apples. The Idealarc Tig 300/300 is more comparable. Both are very good machines if everything works as it should. The Idealarc Tig 250/250 isn't nearly as common. It's a good machine but not in the same league. The Miller will draw a lot more amps input power.
GMT+8, 2025-12-19 00:35 , Processed in 0.099926 second(s), 18 queries .
