Trailer light brackets - 2nd pair
发表于 2021-9-1 00:10:13 | 显示全部楼层 |阅读模式
Trailer light brackets - again.I started on the second set of trailer light brackets yesterday.  This set is for my nit-picky buddy, Tom.I made mine last week - here's the link for them.  http://weldingweb.com/vbb/showthread.php?t=30256I wanted to do something different on his, so I decided on a 4 sided housing.  I brought home a piece of 6" X 1/4" X 5' flat from the local steel yard.  I didn't take any pics of the build phase, but here's what I've got so far.  Here's the shape I came up with. Notice the flat washer to the left side of the housing.  I found these at the local farm supply store.  They were the perfect size for holding the 2" light grommet, and only .89 each.  I decided to use these, much easier than trying to cut a nice circle twice to weld on the 3" piece of pipe.  Well worth it in my opinion.Here's a couple of close ups - Here's the pair together, the one on the right is almost completed.  I still need to weld the washer on the pipe, but all the welds have been ground off and sanded down.  I think this one looks really good.  Tom came by last night while I was working on these and brought a me a 30 pack of Busch Light.  I told him I was gonna send them off to be chrome plated!!  A few more of the right one. I couldn't make any money selling these for sure.  I've got several hours in this project already, but it's just for fun anyhow.  On a positive note, he shouldn't be able to tear these off since they're made out of 1/4" material!!
Reply:That looks pretty darn nice.Dude brings a 30 pack (and he probably drank half of it while y'all were standin' around admiring the light boxes).  I hope he left ya some"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Originally Posted by farmersammThat looks pretty darn nice.Dude brings a 30 pack (and he probably drank half of it while y'all were standin' around admiring the light boxes).  I hope he left ya some
Reply:"Any day above ground is a good day"http://www.farmersamm.com/
Reply:am i seein you gas welded that with a cuttin tip???
Reply:Originally Posted by weldbeadam i seein you gas welded that with a cuttin tip???
Reply:Ok, I gotta come clean with ya weldbead.  I used my flux core wire welder on the whole dang project!!I haven't used O/A to weld anything for so long I can't remember the last time.  I think I'll try a little this week just to see if I still have the knack for it!!
Reply:Nice twist from the original design to keep the new ones unique as you indicated earlier was your desire.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:You might want to wear shin gaurds around those....Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Originally Posted by lugweldYou might want to wear shin gaurds around those....
Reply:CUP CHECK !!!Nice work on your new set of light housings.  Just make sure you aren't working on that 30-pack at the same time you're working with your welder ...... might spill your beer.
Reply:Originally Posted by SpyGuyCUP CHECK !!!Nice work on your new set of light housings.  Just make sure you aren't working on that 30-pack at the same time you're working with your welder ...... might spill your beer.
GMT+8, 2025-12-23 11:20 , Processed in 0.066593 second(s), 18 queries .
