Just another welding table...:)
发表于 2021-9-1 00:10:13 | 显示全部楼层 |阅读模式
Well I finally built the welding table I so desperately needed. Being limited on space in my 16x24 garage, I designed the table to slip over my welder when not in use. It turned out great and I got all the materials free from work excluding the plate and castors! The top is 1/4" plate and very solid with 3 cross members under it every 12 inches. I will be adding a mig gun holder and a few other little tweaks as I go along. Sure beats working on the floor! Cheers! Edit* For got to mention that it's 3.5' wide x 2.5 feet deep.Chad.Last edited by Big_Pink_Snapper; 03-11-2009 at 08:09 AM.Reason: Forgot dimensions...Millermatic 210
Reply:Great use of your space. Looks good too, Like the color match.
Reply:Smart the way it slides over the welder.  You haven't used up one inch of additional space.Now ya got somethin' to pile more stuff on"Any day above ground is a good day"http://www.farmersamm.com/
Reply:That is a great idea.  Nesting them keeps the welder from damage when stored and being on wheels it takes a minute to set up for a job Gordie -- "I believe you understand what you think I said, but I'm not sure you realize that what you heard is not what I meant."
Reply:Thanks for the positive replies. You can't see it in the pictures but I left 2 1/2 inches of overhang on each of the lengthy sides for clamping and the ends of the tubing are open for fitting my welding clamp etc.Millermatic 210
Reply:Great Idea about nesting over the welder. May have to rethink mine.Miller 140 w A/SHF Flux Core WelderDewalt Chop SawSmith O/A TorchHarley Electra Glide Classic
Reply:Great idea!  I started planning one for me and realized that my bottle is a little too tall.
Reply:Nice!Kevin's Welding Service.Miller Bobcat 250.Millermatic 212.Hypertherm Powermax 600.Victor Journeyman torch set.Speedglas 9000XL
Reply:Neat design, almost wish I hadn't traded up to an 80 cuft tank. What is the frame made of???fredLast edited by fredf; 05-12-2009 at 09:31 PM.
Reply:This is another example of a well thought out & executed project. Good job
Reply:looks like you've gto a nice setup shop.  the only thing i can critique on, and i'm sure you thought of this, is that you may want to switch to a bigger tank one day.
Reply:Originally Posted by Big_Pink_SnapperThanks for the positive replies. You can't see it in the pictures but I left 2 1/2 inches of overhang on each of the lengthy sides for clamping and the ends of the tubing are open for fitting my welding clamp etc.
GMT+8, 2025-12-23 11:17 , Processed in 0.091896 second(s), 18 queries .
