Front ATV Cargo Box
发表于 2021-9-1 00:10:13 | 显示全部楼层 |阅读模式
My first welding job...I built this box because I needed more cargo room on my four wheeler. I wanted something water proof and rugged. On the internet they were well over $200. I didn't really want extra lights, but after the box was an inch to high, it covered my handle bar light. So now this box can be submerged a few feet and no water gets in. Water seal, water proof lights, and painted with truck bed liners spray paint.If I could do it again...I would make it all out of sheet metal or aluminum, using my 16 gauge break. I would not make a frame out of quarter inch square at all. Also, I would not prime it, or at least use the primer I used. I would also never use BONDO again to cover the curves. I would do a much better job with the silicone as well. I would also make the lights internally inside of the box. I would also make it a lot cleaner on the inside.Pros:The box comes off and on in less then 8 seconds due to those little wing nut nob "thingies".Could add a rifle mount, cooler, bad, on the diamond plate.Strong enough to stand on.Light switches are water proof, and an extra switch for any additions.Removable power supply.Box is 3.5 inches in the rear 5.5 in the front which allow the top to be flat.LockableCons:The paint; I wish I new more about painting. I would have preferred to use some kind of ceramic paint, and would have like to get into powder coating the surface.The silicone could have and should be nicer. The sheet metal is wavy due to the way I welded it on.Conclusion: I am going to completely re design and create my next cargo box. I would like to make it out of aluminum. Internal lights, and waterproof. The paint is the real question. Any ideas?
Reply:Does'nt look bad from here at all,looks pretty clean actually,2 drink holders on front ,you must get really thirsty.      Lincoln 225 ACLincoln Mig Pak 15Lincoln Mig Pak 10Purox Oxy-Acet Outfit20 Ton PressHonda Generator
Reply:Good job, I have an old military metal rocket box I put on mine, Has a watertight lid and secure latches, w/ grab handle on each end. No lights, my headlite is under the rack. I just fasten it down w/ a rubber snubber thru each handle. I also have a bolt on homemade rifle rack that goes on the lid.                               MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:try driving at night, you might get a lot of reflection or glare from your headlight.  Other than that it looks good for rev 1!
Reply:Lookin good!!!    you just gotta nit pic it to death don't ya I do too don't we all ,  thats what design and redesign is all about trial and error right. As you know your faults as a build designer does it will make for a better product next time.... all in all I still need one of those for my Polaris and I would happily use that one you did a great job.  I like the locks and it's not plastic woot woot.Lincoln 225 Tombstone,Miller Big 20,Hobart 180,150' Argon,A/D hobart hood 22 Ton Log splitter,79 F350 dump eats 4.75 TONS and still turns cutters,grinders,And a  Hypertherm POWERMAX 30
Reply:Looks good! About every project you do, you always think of ways to do it better.Miller 140 w A/SHF Flux Core WelderDewalt Chop SawSmith O/A TorchHarley Electra Glide Classic
Reply:i must be missing something but whats that third cable for, at first i thought it was a coaxial cable for a CB, but no antenna.  and it's got 2 wires on it..
GMT+8, 2025-12-23 11:17 , Processed in 0.230551 second(s), 18 queries .
