started a trailer for friend
发表于 2021-9-1 00:10:11 | 显示全部楼层 |阅读模式
I started a trailer for a friend that doesnt have alot of money to spend on a store bought trailer. The guy helps everyone out that he can without asking for anything in return. He'd give you the shirt off his back even if  it was his only shirt. I have alot of scrap metal and an axle from my other trailer I'm still working on, since I'm putting another axle under mine. He's going to help me with some concrete work for trade for the trailer. It's 4.5 ft. wide and 8 ft long , tubing is 2"x4" x1/8" thick. orange tubing is 1 1/2 "x 3"x 1/8"l ast pic is my son helping clean out the tubing,he loves spraying everything Attached Images It's not what you can buy, it's what you can build that matters
Reply:Looks like you're off to a good start there
Reply:axle on today Attached Images It's not what you can buy, it's what you can build that matters
Reply:I'm probably just a worry wart...but I'd add some triangulation...maybe in this area??Its looking very nice! (and heavy!)...are those tires DOT rated?  they look like "Terra Tires" for golf course equipment in the picture...will destroy themselves on the interstate....Good Job, and congrats on giving a hand to someone who could use it!Maybe we should all vow to do one "helping hand" freebie welding job a year...not a bad idea, eh?  It could be a simple as a bicycle, go kart, lawnmower, etc. repair, or a full fledged deluxe project like yours...Last edited by hillco; 04-02-2009 at 11:27 PM."Good Enough Never Is"MIller AC/DC  ThunderboltHobart HH180, 125EZRiland Cut 40 Plasma oxy/act  outfitTons of "stuff", all treasures to me!
Reply:Planning on lots of tongue weight?
Reply:hillco i was think of the bracing also like you 've drawn. the tires are off a camper and are actually  e rated so they're rated at 1500lbs each.MAC702 not expecting much weight it's just the material i had on hand. It's not what you can buy, it's what you can build that matters
Reply:Looks good,I'm thiking about biulding a 5 x 10 trailer in the near future.How do you decide where to put the axle,some i see are centered and some are placed a bit to the rear?Lincoln 225 ACLincoln Mig Pak 15Lincoln Mig Pak 10Purox Oxy-Acet Outfit20 Ton PressHonda Generator
Reply:hytek,I think mac's comment was related to the kind-of rearward position of the axle, which would mean that a lot of the weight of the load on the trailer would end up on the hitch as tongue weight and not as load on the axle.Ahhh, running the numbers it looks like it is actually nicely laid out there.With an 8 ft long trailer, and a WAG (Wild A## Guess  ) on the axle 3 ft from the back end of the trailer and the distance from the hitch to the axle of 10 ft, that actually comes out as textbook perfect 10% tongue weight for an evenly distributed load on the trailer.  Triangulation braces from the tongue to the frame would be a good thing.  The best laid schemes ... Gang oft agley ...
Reply:trailer almost completed Attached Images It's not what you can buy, it's what you can build that matters
GMT+8, 2025-12-23 13:11 , Processed in 0.069870 second(s), 18 queries .
