Zinc based die-cast
发表于 2021-9-1 00:10:09 | 显示全部楼层 |阅读模式
New guy on the block with ?'s about zinc based die-cast. Is there a good way to identify it and can it be welded ? Sorry I don't have a camera to send a pic. The piece in ? is a fender mount off a Honda motorcycle don't know model or year. Thanks for any help.Doug
Reply:Grind off the coating and weld it. The only issue is, it won't look the same, then you'll either need to have it re-coated or paint it.John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Originally Posted by MicroZoneGrind off the coating and weld it. The only issue is, it won't look the same, then you'll either need to have it re-coated or paint it.
Reply:It's white metal die cast or pot metal.
Reply:It will fuse with tig on a.c.I did some last Saturday during class on a band saw guard..At first I had thought it was aluminum but no..Microzone was there......zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Originally Posted by zapsterIt will fuse with tig on a.c.I did some last Saturday during class on a band saw guard..At first I had thought it was aluminum but no..Microzone was there......zap!
Reply:Originally Posted by WaldarosaThanks I'll give a shot today. When I've tried pot metal with TIG before it just turned into a blob. Zap what did you use for filler?
Reply:Thanks for the help. Got the pot metal TIG welded.
Reply:Another happy customer!...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
GMT+8, 2025-12-23 11:16 , Processed in 0.116810 second(s), 18 queries .
