Adding a spool gun to my current welder?
发表于 2021-9-1 00:10:08 | 显示全部楼层 |阅读模式
I currently own a Chicago Electric "Dual Mig 151" welder. I bought an OxyAcetylene Setup mainly so Id be able to weld Aluminum, but I am concerned about my success in Al with this setup (not only the ability to lay down a decent bead, but the effects of the heat input into the Al, and the structural integrity of the weld).Question: Is there a way to convert my MIG to use a spoolgun or anything like that?If not, and I dont get the O/A to work with Al like Id hoped, then Ill just save up a bit more and either get a new Spool Gunned MIG or a TIG.
Reply:I started learning MIG welding with the same machine you have.It will feed aluminum -- I've run plenty of 4043 aluminum wire through it -- no real problems.  The liner is some sort of plastic or vinyl that is OK for Al.Make sure your tip is one size larger than the wire.
Reply:Hmm...Is Argon the universal gas for welding Al (with MIG, TIG, etc)? If so, then maybe Ill just buy an argon tank and try it out!
Reply:J Argon is the shielding gas to use for mig Al. flow rate of 15-25 C.F.H.
Reply:Nevermind.Last edited by JMcDonald; 05-11-2007 at 03:44 PM.
GMT+8, 2025-12-23 11:33 , Processed in 0.105218 second(s), 18 queries .
