Repairing Lincoln AC 225 Welder
发表于 2021-9-1 00:10:05 | 显示全部楼层 |阅读模式
I have a question maybe someone can help me with.One of my old welders an ac 225 lincoln,the dial where you adjust the amperage has frozen or locked up.What do i do to fix this? Or should I junk it?Thanks
Reply:The quick answer is yes, you should be able to fix that quite easily - pull off the side/top panel, take apart the rotary switch, clean all the contacts, grease them slightly and put the switch back together.  Should work like a charm.If you use the 'search' function, you will turn up two threads on this - with lots of pictures and detailed instructions of how to do that.Restoring your Lincoln AC-225 welderhttp://weldingweb.com/vbb/showthread.php?t=4533Refurb of a Lincoln Lincwelder AC-225-shttp://weldingweb.com/vbb/showthread.php?t=59987Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:Somehow the first lik got screwed up!Try http://weldingweb.com/vbb/showthread.php?t=45337Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
GMT+8, 2025-12-23 11:29 , Processed in 0.093089 second(s), 18 queries .
