Div. 05
发表于 2021-9-1 00:10:04 | 显示全部楼层 |阅读模式
Thought some might like to see this Attached ImagesPages 2-3 Div 05.pdf (48.1 KB, 118 views)
Reply:I have seen those classifications before at one shop I worked with.  It was attached to pictures that further defined the joint definition.  Thanks for the post.
Reply:I should have named the thread differently so the 7014 discussion folks would see it.
GMT+8, 2025-12-23 11:17 , Processed in 0.089091 second(s), 18 queries .
