Wire Feed question
发表于 2021-9-1 00:10:04 | 显示全部楼层 |阅读模式
Hi all- New to welding so I borrowed a friends Mighty Mig 101, 85 max amps, 110V with low hours on it. The wire feed speed control isn't working(fuse is good) and from what I've read that controls the amps and power settings control the volts(?). Amps will give me the heat needed for good penetration? Wire comes out very fast and I can't really get any pen at max settings. I'm trying to weld some 1/8" plate to 1/16" square stock. I can pull off most welds with a pair of vise-grips. Is wire feed being to fast my problem? Plugged unit into 110V, 20 amp circuit. TIA for replies-
Reply:Post some pictures.Many variables to consider.
Reply:does it have a chart under the door???F/C  or hard wire??leads hooked up correctly? for said wirepics and or settings wire feed speed does have an affect on heat settings takes more amps to burn more wire sounds like you R too cold for your wire speedidealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
GMT+8, 2025-12-23 13:12 , Processed in 0.092762 second(s), 18 queries .
