steel headboard
发表于 2021-9-1 00:10:03 | 显示全部楼层 |阅读模式
Does anyone know where to buy a steel headboard for a bed? Ive built a massive bed frame, and I need a good headboardGo Cards!!!!!
Reply:why not make the headboard also?tackleexperts.comwww.necessityjigs.comhttps://www.facebook.com/groups/mach...dingequipment/
Reply:If you can build the frame, you should be able to build the head board.
Reply:^ That is my thought also...Lincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
Reply:Like this?It's just welding. How hard is that?Two turn tables and a microphone.
Reply:On a second note, headboards are a pain when they are banging against the wallLincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
Reply:Yeah man, have fun an be creative. Just done forget about the D-Rings [Account Abandoned 8/8/16 Please Do Not Attempt Contact Or Expect A Reply]. See you on YouTube! -ChuckE2009
Reply:Cliff, just do a search... I've seen quite a few posts on here from guys that have built headboards. Some quite simple, and some very ornate.  It's worth a look if you have the time to make your own.Miller Dynasty 200DXMillermatic 210 w/ Spoolmate 3035Hypertherm Powermax 380JD Squared Model 32Multiple fabrication tools & equipmentFull Powder Coating Setup
Reply:If I build my own headboard/footboard combo, it would be so heavy and overbuilt, I don't think it would be practicalGo Cards!!!!!
GMT+8, 2025-12-23 10:59 , Processed in 0.091977 second(s), 18 queries .
