another look at my welds thread
发表于 2021-9-1 00:10:03 | 显示全部楼层 |阅读模式
Well, had my 180 for over a year and never used it. Thought today was perfect so I tried it out. Now, I'm not sure if these welds are good or bad so that's why I'm posting them up.First, I tried some spot welds. Starting from the left towards the right.Then, I laid some beads. The one one the right was first, then the left and the middle last.I did some more welds on the other side, starting from the top left going to the right.And my improvised cart.I think I did ok overall. Think I need to calm down and slow down a little. I was just so excited. What do ya'll think?Lincoln Promig 180
Reply:kinda looks like ur settings were to hot, lots of spatter a paint scraper knocks that stuff off fairly good(just my opinion)
Reply:I was using innershield on the lowest voltage setting. Maybe using regular wire and gas would be better with this metal?Lincoln Promig 180
Reply:I would use a heavier ext. cord first of all. But other than that like you said calm down get comfortable and go slow.
Reply:Originally Posted by landmanI would use a heavier ext. cord first of all. But other than that like you said calm down get comfortable and go slow.
Reply:Originally Posted by willinthe985I was using innershield on the lowest voltage setting. Maybe using regular wire and gas would be better with this metal?
Reply:Originally Posted by SandyYou've used 200 inches wire and you'r ready to change ?? Honest, you haven't started yet . Don't worry about your beads just yet. You have lots of practice yet to go.
Reply:Just keep practicing. Ive used innershield on everything from 20 guage to 1/2. Great wire!! Get out there and practice. Not bad for a first time!Ya gotta spend money to make money!
Reply:Just crank it up full and letter rip!Don't be shy about running lots of practice beads, you have to get warmed up a bit! City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:Those bed frames take a slow start to get good penetration going (heat them up a little) No preheat needed, just start slower on them. Once the weld heats the metal up it goes fine. Slow down a little and wait till you see the puddle. And as said not bad for a beginner, practice practice practice.Miller Thunderbolt 225Millermatic 130 XPLincoln HD 100 Forney C-5bt Arc welderPlasma Cutter Gianteach Cut40ACent Machinery Bandsaw Cent Machinery 16Speed Drill PressChicago Electric 130amp tig/90 ArcHobart 190 Mig spoolgun ready
Reply:Thanks guys, I'll definitely be practicing more this week.Lincoln Promig 180
GMT+8, 2025-12-23 11:20 , Processed in 0.072338 second(s), 18 queries .
