Steering question
发表于 2021-9-1 00:10:02 | 显示全部楼层 |阅读模式
I finally got my cart on the ground for a road test and it steers backwards.My pivot is in the front, does it need to be in the back?I don't have a very good understanding about steering and this was my first attempt.The cart is not finished yet, I still ned to add the drawer assemblies and finish the tank retention and electrical. Attached Images
Reply:Just face the other way when you use it and all should be fine!
Reply:Tie rods and handle need to be on the same side of the pivot point.
GMT+8, 2025-12-23 11:31 , Processed in 0.166609 second(s), 18 queries .
