miller 35s question
发表于 2021-9-1 00:09:52 | 显示全部楼层 |阅读模式
i just picked this up from a buddy for free!!!!!  works like a charm.  what range of mild steel will this weld with gas?  thanks,  jason
Reply:Are you talking about a MillerMatic 35 mig power source with integrated wire feed?MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:this is a 1970's mig welder.  it is big about 40" tall 16" wide and 30" deep  that is all i know about it.  it says millermatic 35S   thanks
Reply:Find the SN located on the faceplate of the unit and go here http://www.millerwelds.com/service/ownersmanuals.php to get the manual for it and you'll have pretty much all you'll need to know about it.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:That has to be the MillerMatic 35 then.  I don't know anything about the 'S' on the end of the name, maybe it originally came with a Spoolmatic spool gun as a package deal.You can weld just about anything you want to in steel with proper joint prep and enough passes.  1/4" v-groove or fillet in a single pass should be no problem for it.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Is it a 120v machine?  If so, I wouldn't weld anything over 3/16", 1/4" MAXIMUM, with a few passes.  I have the MM 135 (regular, not S), and it's a fun little unit!  Have a Jeep Cherokee?  Click Here!
Reply:220v machine. 150 amps @ 60%.Manualhttp://www.millerwelds.com/om/o1301b_mil.pdf.No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:it is a 220 serial # on front panel is  72-616879  it keeps telling me it is an invalid model/ serial # combination....
Reply:i am trying to find out up to what thickness this will weld.  thanks,jason
Reply:Originally Posted by cowhead5065i am trying to find out up to what thickness this will weld.  thanks,jason
Reply:thanks
Reply:I am looking at one of these machines at an auction goin on right now, i am curious what one is worth, they claim it works but dont know for sure. any help would b great, thanks-1982 GMC 1Ton- Ranger 9-Esab Mig and Plasma
Reply:I may be wrong but that machine in the used market usually brings $5-600.00 all day long and I have seen them listed for quite a bit more. It's getting old but still has good part availability and is pretty reliable as it is not a complex as many or today's unit. Have used Millermatic 35's for a lot of work. Good friend, better take him out for beers and a steak or something."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:Ive had a MM35 for 10 years now that 150 amp is kinda underating it I think. with a 90/10 gas it will spray 0.30 wire prolly 0.35 too. I use the 90/10 .030 with my MM 35 all the time works great for flat and vertical, not so well overhead i dont have enough wire speed my dial is cranked all the time on number 3 and higher.
GMT+8, 2025-12-23 11:07 , Processed in 0.093872 second(s), 18 queries .
