S.s. Grill
发表于 2021-9-1 00:09:47 | 显示全部楼层 |阅读模式
Im looking to replace my rusty grill top with 304 stainless steel 3/8" round bar1) would this be a good stainless to eat off of or should i look for something else2) can i get away with using 25/75 gas with the stainless steelany help would be greatly appreciatedim using a millermatic 210                             thanks dave
Reply:what type wire are you using. if you use wire for steel just weld it toward the ends away from the cooking areas. should be good to go but if you can use a stainless wire  dont know what you have at yor shop.daveIf you like my stuff you can find me on Facebook.  https://www.facebook.com/theangryanv...ngryanvilforge
Reply:I think the wire will be 0.30 308 stainless steel
Reply:should work fine. show pics when doneIf you like my stuff you can find me on Facebook.  https://www.facebook.com/theangryanv...ngryanvilforge
Reply:Thanks i will
Reply:304 is fine to eat off, but 3/8 round bar will get pretty pricey pretty quick.  id suggest you go with stainless mesh or stainless expanded metal.  mcmaster carr has it and so does mcnichols (www.mcmaster.com and www.mcnichols.com)
Reply:hi  not hijackin but i recently made an extra grill shelf for my kitchen oven,, used 3/8 ms round bar because its for holding pots, not grilling meat..bent the frame with my hf bender and stuck it together with 7018..paid about $1.50 a foot at tractor supply for the bar. Attached Images
Reply:Actually the price i think really is not that badfor the 3/8" its about $7.00 for a 12' piecethe price for the job will be $70.00for the 1/4" its about $4.23 for a 12' piecethe price for the job will be $42.00the wire .030 308 stainless steel 2lbs $30.00
GMT+8, 2025-12-23 11:27 , Processed in 0.066820 second(s), 18 queries .
