5/8 plate, 1/4" walled 4" x 4" tube. 1/8" 7018 @115A DC+welded position as in the pic. wish drilling the holes were as easy!oh and thats a dime Attached ImagesG
Reply:Ah, the holes. Why I bought a mag drill and a set of annular cutters.
Reply:yea! just ordered the sameG
Reply:nice looking job!
Reply:Originally Posted by paweldorAh, the holes. Why I bought a mag drill and a set of annular cutters.
Reply:I made a set of small plates as guides for the plasma torch. Allowing for the thickness of the tip, each plate renders a hole a specific size. Using the plates as a guide, I can cut holes from 1/2" to 1-1/2" in increments of 1/16". First, without using the guide plate, I pierce a hole in the plate. Then I locate the plate and simply follow the guide while cutting. A touch-up with the grinder and you're good to go.It doesn't quite offer the precision of a drilled hole, but if you're just gonna bolt something together, it's more than close enough. I only use my mag drill when I have to.The best things in life all come on a stick!
Reply:Originally Posted by gordfraser5/8 plate, 1/4" walled 4" x 4" tube. 1/8" 7018 @115A DC+welded position as in the pic. wish drilling the holes were as easy!oh and thats a dime
Reply:[QUOTE=wish drilling the holes were as easy![/QUOTE]why, is it so difficult to drill. what you use, not a pillar drill, a hand driller?
Reply:sorry for the delayJr.pulling. pointing the rod back at about 15 to 20 degrees and @40 degrees from the horizontal.junior:used a cheap and nasty drillpress with twist drills.....lots of steps!got the magdrill now so its mo problem.G |
