Free pressure washer
发表于 2021-9-1 00:09:44 | 显示全部楼层 |阅读模式
Hello all. driving home from church the other day. I noticed a driveway filled with baby cloths and computer cables. naturally i looked around, at the back was a 6.5 hp 2300 gas pressure washer. for free. turns out the owner is a lawyer and just wanted to clean out his garage.the washer has four o ring's all are eaten away, and i haven't a clue as to what type they are. if anyone can identify them please speak up as I'm using RTV silicone right now and its leaking a lot. Attached Images
Reply:I don't think there anything fancy. you can prolly call up the manufacture and they will have a rebuild kit that will have all those o rings you need. Homedepot i believe has o rings might see if they have the right sizeMillermatic DVIMillermatic 251Older buzz box Cheap 120 welder
Reply:Thanks, I've been wanting to use it for some time now.
Reply:For deal like that you could go buy a whole universal O-ring kit and have plenty of O-rings left over for the next project.Tough as nails and damn near as smart
Reply:Any car repair shop is going to have a universal o-ring set, if someone was to walk into my shop looking for a couple of o-rings I would just give them to them. I can only assume that other shops are the same way.Miller millermatic 251Miller aircrafter 330st, wp201961 Lincoln SA200Ellis 1600 bandsawLogan 820 latheSouth Bend 13"Bridgeport M Head
Reply:Harbor Freight has O ring set about 12.00 if i remember correctly and it's a 250 piece set.Miller Thunderbolt 225Millermatic 130 XPLincoln HD 100 Forney C-5bt Arc welderPlasma Cutter Gianteach Cut40ACent Machinery Bandsaw Cent Machinery 16Speed Drill PressChicago Electric 130amp tig/90 ArcHobart 190 Mig spoolgun ready
Reply:Ace hardware - all sizes but expensive.A butterfly without wings, is just an ugly bug
Reply:Awesome score llamafur!I'm with all the posts so far as for where to find replacement o-rings.  Should be a pretty easy fix for you.  Keep us posted.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:thanks, as I'm only 17 and still learning.
Reply:That's OK - I'm still learning and I'm 54.  Just don't ever stop being willing to.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:I love learning. I'm not an expert in everything, but I know enough to understand.I can do anything if I'm given the right tools and instructions.
Reply:Check here: http://www.pressureparts.com/PumpKit...-Category.aspxJust look up your pump model!#1. If you don't like what I wrote, or if it offends you, then don't read it!#2. I am living life the way I see fit, if you don't like the way I'M living, tough sh**!
Reply:Where are the orings located?  If they are around the input/output, then no problem.  If it's leaking around the pump head, you may be looking at a pump rebuild.  But still that's no problem, just open and replace parts.  Call PressureTek in Cleveland at 1-866-700-0044.  Ask for Bob or Andy - both VERY friendly and helpful.  They will have you rolling in no time.  Tell them Jason in Mississippi sent you.
Reply:theres four of them. lined up near the four hex screws. i'll post pic when i get home.
Reply:Nice score.  Hope you get it running soon.The only time you stop learning is when you stop breathing.
Reply:I thought I stopped learning once!Then I learned that I didn't know as much as I thought I did, so I began thinking I better start learning again!   #1. If you don't like what I wrote, or if it offends you, then don't read it!#2. I am living life the way I see fit, if you don't like the way I'M living, tough sh**!
GMT+8, 2025-12-23 11:31 , Processed in 0.104861 second(s), 18 queries .
