Old Age, Alzheimers, Or Just Plain Stupidity?
发表于 2021-9-1 00:09:43 | 显示全部楼层 |阅读模式
I took the most beautifully machined piece of metal since the Hubble Telescope, and turned it into the equilavent of a tin can waitin' to be kicked down the roadThe sector has to stand off from the base plate enough to give clearance for the lever to work, and the metal that joins it to the base plate has to be out of the way of the pawl thingy where it rides next to the plate.  The outside of the sector doesn't matter, it's free.The front bolt hole on the machine is in absolutely the worst place it could beSo anyhow..........  I finally figured out how to shim the sector to give the proper standoff.Now I'm puttin' it together.  Breezin' right alongBetween the bolt hole/plate, there's a stack of metal.  3/8 flat, with another piece of 3/8 further out, and finally 1/2 flat to match the sector.  Like a sandwich.Somehwere in all the hubub, I forgot how the part was oriented in relation to the machine.  IE, which side faced out, and which side faced in.  I was just concerned about providing a surface for a fillet weld on all three pieces.  I didn't feel like beveling and welding every piece on the edges.  A time saverI'm tempted to blame this on the refreshments.  Kinda hot today, and lately I've gotten a taste for orange soda.  Usually it's Orange Crush, but yesterday I picked up some Sunkist.  Now here's the kicker...........  Orange Crush is caffiene free,  Sunkist ain't  I snarfed down 3 of those puppies this afternoon.I'm higher'n a kite after all this sugar and caffiene.  (I'm usually a water dude)So, I'm leanin' towards blamin' this on the evils of Sunkist Orange SodaI'm so fed up with it, I refuse to rework the part.  I will, to my dying day, walk by this thing and grit my teeth.  It'll work fine, but it's just not RIGHT!!!!!!!!!!  It's a matter of ASSTHETICS.  ROFLMAO.RE the pics.......  As usual, this is a build from the machine out.  Sector clamped and temp welded in place, and all other parts welded to fit.  Final bevel, tack, and weld, where the part meets the sector will be done last.  This helps to prevent distortion.  It also allows you to adjust dimensions and fit before committing to a final weldup.I'm tellin' ya..........It was the sodaThe final pic (before the usual photo of the QC dude) is how the last piece of the sandwich should have been cut.  THE FILLET'S ON THE WRONG SIDE!!!!!!!!!!!!! $%%$#$#@!&^ Attached Images"Any day above ground is a good day"http://www.farmersamm.com/
Reply:..... Attached Images"Any day above ground is a good day"http://www.farmersamm.com/
Reply:"Any day above ground is a good day" I agree that your work rivals the Hubble. I spent a lot of time kicking my butt 'cuz it ain't perfect. So did my ex-wife. I got over both of 'em. It's the male DNA to screw things up. Women never screw things up.......because they never make anything.  Everything we make is a 'one off'. Mistakes are inevitable. NASA built a bazillion parts before they got the Hubble right. Heck, they had to send a dozen guys to the moon to get the Hubble right. You've been in the Denver area and know yer 'posed ta drink Orange Crush. Sunkist is bad juju. The QC guy seems OK with the finished product. 9-11-2001......We Will Never ForgetRetired desk jockey. Hobby weldor with a little training. Craftsman O/A---Flat, Vert, Ovhd, Horz. Miller Syncrowave 250
Reply:I'd blame it on the QC man, he should've been watchin DewayneDixieland WeldingMM350PLincoln 100Some torchesOther misc. tools
Reply:Nothing a little ductape won't fix!
Reply:But the weld looks awesome!Gotta give yourself credit for that! #1. If you don't like what I wrote, or if it offends you, then don't read it!#2. I am living life the way I see fit, if you don't like the way I'M living, tough sh**!
Reply:....... or a LOT of duct tape .............. Old age?  Nope, you're not really all that old.Stupidity?  no, seen a bunch of your stuff, so lets that out .....Alzheimer's?  PossiblyYou know one of the good things about having Alzheimer's?  You get to hide your own Easter eggs ....
Reply:Originally Posted by SpyGuy....... or a LOT of duct tape .............. Old age?  Nope, you're not really all that old.Stupidity?  no, seen a bunch of your stuff, so lets that out .....Alzheimer's?  PossiblyYou know one of the good things about having Alzheimer's?  You get to hide your own Easter eggs ....
Reply:Couldn't handle lookin' at it for the rest of my lifeSo I decided to do a redo.Sliced it up with a razor wheel, and corrected my brain freeze/fart/burp..... whateverNobody on the planet is ever going to see this thing, but I couldn't let it go like it was Attached Images"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Razor wheel, very dangerous thingThey like to bind and kick back, and they like to delaminate and shatter.  A last resort tool specially when making a deep cut."Any day above ground is a good day"http://www.farmersamm.com/
Reply:Yep!Don't care for them myself either.For that, I would have preferred to use one of them thar small cut off wheels on a circular saw, and set the depth of cut on the saws base for that.Lots safer!#1. If you don't like what I wrote, or if it offends you, then don't read it!#2. I am living life the way I see fit, if you don't like the way I'M living, tough sh**!
Reply:I think it is a great project and you did a fantastic job there, Farmersamm!!I have an antidote for the caffine-laced orange soda.  See photo.-Mondo Attached ImagesMember, AWSLincoln ProMIG 140Lincoln AC TombstoneCraftsman Lathe 12 x 24 c1935Atlas MFC Horizontal MillCraftsman Commercial Lathe 12 x 36 c1970- - - I'll just keep on keepin' on.
Reply:Ohoh!Mondo!Pass that over here and I will make sure samm gets the bottle!  Empty you say? #1. If you don't like what I wrote, or if it offends you, then don't read it!#2. I am living life the way I see fit, if you don't like the way I'M living, tough sh**!
GMT+8, 2025-12-23 10:59 , Processed in 0.084647 second(s), 18 queries .
