Clamps
发表于 2021-9-1 00:09:35 | 显示全部楼层 |阅读模式
What kind of clamps do you use? Looking for advice on clamping rectangle tube at right angles and in t's. Thanks.
Reply:I have a few corner clamps from various manufacturers. Mostly I use them for temporary setup and measurements when working alone. Saves having to bust tacks all the time when fitting. 90+% of the time I simply use a framing square and tack the pieces in place rather than use the clamps when it comes to assembly..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:i have clamps but can count on a couple fingers the times i used them. like DSW said square it, tack it, square it, tack it, weld it.225NT bobcatAEAD200LEScott 125mm175, mm252 w 30A, PT225mm211, TA 181iHyper Therm 380, cut master 529100X & XX, Digital Elite6 Victor setssmith little torch, meco midget kalamazoo band sawsteel max saw evoulution circular saw
GMT+8, 2025-12-23 11:00 , Processed in 0.121714 second(s), 18 queries .
