Welding Cable Lugs
发表于 2021-9-1 00:09:35 | 显示全部楼层 |阅读模式
I have 1/0 welding cable and the 300amp ground clamp as seen here,the problem i'm having is finding a 1/0 cable lug rated for 300amps the closet thing as far as amps is tweco's T-40HD-25 rated for 325amps but for a 4/0 cable. http://www.thermadyne.com/tweco/prod...5Code=&W6Code= And as far as other company's such as hobart i can't find any amp specifications, can somebody point me in the right direction where i can purchase the correction lug, the stud on the ground clamp is 3/8.
Reply:try Air Gas. check the other end at the machine and match it.Last edited by jbmprods; 09-16-2011 at 02:28 PM.225NT bobcatAEAD200LEScott 125mm175, mm252 w 30A, PT225mm211, TA 181iHyper Therm 380, cut master 529100X & XX, Digital Elite6 Victor setssmith little torch, meco midget kalamazoo band sawsteel max saw evoulution circular saw
Reply:I don't have a lug at the other end of the cable, im using the quick connectors.
Reply:Originally Posted by royalblue302I don't have a lug at the other end of the cable, im using the quick connectors.
Reply:thats, whats on the other end
Reply:in less time then it's taken to discuss this i'd use the down home farm boy heavy equipment mechanic American ingenuity rig welder method and get a piece of thick walled copper tubing and manufacture my own lug and get to welding 225NT bobcatAEAD200LEScott 125mm175, mm252 w 30A, PT225mm211, TA 181iHyper Therm 380, cut master 529100X & XX, Digital Elite6 Victor setssmith little torch, meco midget kalamazoo band sawsteel max saw evoulution circular saw
Reply:thats actually a pretty good idea,  haha
Reply:im really liking this here, but again no spec's. http://www.weldfabulous.com/Welding-...-p7541552.html
Reply:it looks like it would work fine. as for amperage it doesn't take much solid material to carry the amps for such a short distance from the stud to the cable. not like the run on a length of actual stranded cable. my concern would be the size of the hole in the lug plus i prefer the bare copper. less resistance and oxidation of dissimilar metals. that's why i would make it out of copper and size the hole to fit tight. if in doubt of just a crimp, do both crimp and solder.225NT bobcatAEAD200LEScott 125mm175, mm252 w 30A, PT225mm211, TA 181iHyper Therm 380, cut master 529100X & XX, Digital Elite6 Victor setssmith little torch, meco midget kalamazoo band sawsteel max saw evoulution circular saw
GMT+8, 2025-12-23 11:27 , Processed in 0.104245 second(s), 19 queries .
