Workbench for my garage. Take 2.
发表于 2021-9-1 00:09:31 | 显示全部楼层 |阅读模式
So I started another workbench last week and today I cut it up to start this one. I am much happier with this design. Attached Images
Reply:This as far as I got today Attached Images
Reply:That's the beauty of being able to cut things apart and weld them back together.  Keep the photos coming.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:OK I am lost.  Why do you have those pieces clamped to the ones you are going to weld?
Reply:Originally Posted by partagasOK I am lost.  Why do you have those pieces clamped to the ones you are going to weld?
Reply:i think hes useing the tube as a ground
Reply:Looks to me like he is clamping to the welding area to ensure that it remains straight and in line, and when dressed will look just like one peice box section.  Cheers  Gordon.Lincoln SP-170 MigHypertherm powermax 45Lorch T220 AC/DC TigButters FM 215 synergic MigKemppi 180 adaptive mig RULES ARE FOR THE OBEDIENCE OF FOOLS AND THE  GUIDANCE OF WISE MEN.
Reply:Originally Posted by gordon stephensonLooks to me like he is clamping to the welding area to ensure that it remains straight and in line, and when dressed will look just like one peice box section.  Cheers  Gordon.
Reply:It will nice once you have a tableEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:What are you going to use for a top?IF IT WORKS, DON'T FIX IT2 Lincoln CV-300 / LN-7 GMALinde-VI 253,400 & 450 w/MIG35 feedersCNC Table with Oxweld O/A & Hypertherm 1250G3Lincoln Ranger GXT 250Hobart-MicroWire 300ESAB Heliarc 161ESAB-Mobilemaster 2 CC/CV Feeders& more
Reply:Originally Posted by millman52What are you going to use for a top?
Reply:I'm a newb to this whole welding thing...but how do you get those nice beveled edges?Hobart Handler 187Bainbridge bandsawMakita chop sawHarbor Freight 4.5" grinder
Reply:Johnny,Turn up the heat and slightly increase your travel speed; looks like the bead is too high and the toes of the weld could be tied in better to the base material. I like your means of preventing distortion.ScottMiller XMT 350 CC/CV w/gas solenoid opt.Miller S-22A wirefeederBernard 400A "Q" gunMiller Spoolmatic 30A / WC-24C-K 200A torch/gas lensWeldcraft WC-18 watercooled torchHypertherm Powermax 30Victor O/A
Reply:Originally Posted by jetlagI'm a newb to this whole welding thing...but how do you get those nice beveled edges?
Reply:Originally Posted by DmaxerJohnny,Turn up the heat and slightly increase your travel speed; looks like the bead is too high and the toes of the weld could be tied in better to the base material. I like your means of preventing distortion.
Reply:legs finally attached, please excuse the crappy cellphone pic. Attached Images
Reply:Is it parallax from the phone/camera lens or are the legs at this end in this last pic turning in at the bottom?#1. If you don't like what I wrote, or if it offends you, then don't read it!#2. I am living life the way I see fit, if you don't like the way I'M living, tough sh**!
Reply:Originally Posted by Ken DennisIs it parallax from the phone/camera lens or are the legs at this end in this last pic turning in at the bottom?
Reply:Why not consider putting your braces higher,so that they form the support for a shelf under the bench. Would be handy for tools and angle grinders etc while working to keep the work area clear.Also with-out a bottom brace you can more easily store mobile gear underneath.  Best regards  Gordon.Lincoln SP-170 MigHypertherm powermax 45Lorch T220 AC/DC TigButters FM 215 synergic MigKemppi 180 adaptive mig RULES ARE FOR THE OBEDIENCE OF FOOLS AND THE  GUIDANCE OF WISE MEN.
Reply:Ahh!I think what I am seeing is actually whats called fisheye effect!If I where doing this, I would go with what Gordon suggested, a good shelf under a bench is a must for me, if I didn't have at least one, the top of the table would become way too cluttered to get any work done!#1. If you don't like what I wrote, or if it offends you, then don't read it!#2. I am living life the way I see fit, if you don't like the way I'M living, tough sh**!
GMT+8, 2025-12-23 11:27 , Processed in 0.070546 second(s), 18 queries .
