Jack extension
发表于 2021-9-1 00:09:31 | 显示全部楼层 |阅读模式
I've been lurking around this forum for a while now and have decided to try to upload a couple of pics.I work at a farm equipment dealership, I'm a licensed Diesel mechanic and self taught fabricator.  When jacking up the front of larger tractors, we always had stacks of wood blocks to reach the front axle.  We had a tractor slide off the blocks one day so I decided to make a short extension, about 12",  I need to make one about half as long for smaller tractors.Tell me what you think.  The extension is made from 1 9/16" solid round and some pipe that slid over top. the bottom plate is 1/2" freehand torch cut.  All welded with a Millermatic 200 set on High, voltage setting 3, wire speed 60. Attached Images
Reply:Looks good. I might have to steal that idea for my new truck. Usually I try to set the blocks under the jack as it reduces the chance of something slipping.
Reply:Ought to work fine.  The swivel on the lift pad thing always keeps it plumb, so the extension will probably never bend.It's only to lift the tractor to put stands under it anywayYou guys that can weld round stuff MAKE ME WANNA PUKE!!!!!!!  I can't make a nice looking round weld to save my soul"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Excellent idea I think it will work great."SOUTHPAW" A wise person learns from another persons mistakes;A smart person learns from their own mistakes;But, a stupid person.............never learns.
Reply:I did this a long time ago and as long as the load does not roll eveything is fine, However one day my load shifted and with the extra length of the extension acting like a lever it had no trouble at all of bending the trapesium arm/arms that keep the saddle level, the jack shot out at 100mph and luckily nobody was hurt. Just something to keep in mind.  Best regards  Gordon.Lincoln SP-170 MigHypertherm powermax 45Lorch T220 AC/DC TigButters FM 215 synergic MigKemppi 180 adaptive mig RULES ARE FOR THE OBEDIENCE OF FOOLS AND THE  GUIDANCE OF WISE MEN.
Reply:Great idea and nice job Farmer_Joe.Could it be that jack pad comes off as it does because the manufacturer offered/offers an extension(s)?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Originally Posted by gordon stephensonI did this a long time ago and as long as the load does not roll eveything is fine, However one day my load shifted and with the extra length of the extension acting like a lever it had no trouble at all of bending the trapesium arm/arms that keep the saddle level, the jack shot out at 100mph and luckily nobody was hurt. Just something to keep in mind.  Best regards  Gordon.
Reply:Thanks for the feedback.  The jack has about zero chance of kicking out on our shop floor, its about as smooth as a gravel road.  Anyway it has to be safer that a stack of wood blocks, and as farmersamm pointed out it's only for lifting the tractor straight up for stands to be placed underneath.
GMT+8, 2025-12-23 11:16 , Processed in 0.094013 second(s), 18 queries .
