Swamp rat
发表于 2021-9-1 00:09:29 | 显示全部楼层 |阅读模式
Hello , im a new member and just getting my feet weat with a computer.  I have been looking for a adaptor so i can use my torch on a upside down angle iron like a track torch. I do a lot of repair on my equipment and it would be nice to have a way to use my torch as a track torch in the feild ,  would appreciate any info. as to where i can find something of this type.  Thanks.
Reply:What?  You want to use a piece of angle as a cutting guide?Have we all gone mad?
Reply:do you want it to automatically move too? or just a guide to use as a straight edge while manually cutting?
Reply:It kinda sounds like what he wants is something that attaches to the head of the torch so he can make straighter welds .... just my pair of Lincolns.
Reply:Hugh? #1. If you don't like what I wrote, or if it offends you, then don't read it!#2. I am living life the way I see fit, if you don't like the way I'M living, tough sh**!
Reply:These look pretty convenient:http://www.waresdirect.com/products/...ackURL=froogleWe have a magnetic tri-square with an 18" brass rule on it that works okay.. it's made by cruise industrial.  but I cant find anything online about it other that the company information.Common sense in an uncommon degree is what the world calls wisdom.
Reply:I am about to start a project that will include a lot of saddell  work on pipe. I was trying to find a place to order patterns for different size pipe. Will vary from 12" - 24". Any info would be appreciated.
Reply:I was recently looking for some myself.  Here are a few websites to check out for pipe templates.http://www.onestepllc.com/http://www.ezpipe.com/samples.htmhttp://www.weldinginspectionsvcs.com...latesample.htmhttp://www.harderwoods.com/pipedocs.htmlHope those are of some help.I'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
GMT+8, 2025-12-23 11:16 , Processed in 0.091785 second(s), 18 queries .
