The only job more fun than a broken bolt removal is one with a easy out in it!I should have taken more pics.I used 3" cut off to remove 1/2 of bolt boss, then pulled out bolt/easy out, put new bolt into boss, clamped and tig welded with 99ni, unscrewed bolt and tapped hole.PeterPSThe broken bolt has weld on end because I welded nut on it and tried to remove it first, but no go. Next was either mill it out or cut it out. Attached Images
Reply:Nice fix. I'll have to remember that method.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Originally Posted by duaneb55Nice fix. I'll have to remember that method.
Reply:Very nice. Those are the repairs that make you out to be a hero. That is word of mouth advertising.Lincoln Ranger 8 Lincoln 175 Drill pressLincoln 225 mig Plasma 8 ft brake 52" jump shear
Reply:If that's the same Ford motor, I 'm glad someone is puting the time and $$ into restoring it.Way things are going, all that's gonna be left of our auto industry are museum pieces.I'll forget every one of these techniques, even though I've just seen 'em, and have to scream to ya for help if it comes up somewhere down the road. Human nature"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Originally Posted by gclampVery nice. Those are the repairs that make you out to be a hero. That is word of mouth advertising.
Reply:Originally Posted by farmersammIf that's the same Ford motor, I 'm glad someone is puting the time and $$ into restoring it.Way things are going, all that's gonna be left of our auto industry are museum pieces.I'll forget every one of these techniques, even though I've just seen 'em, and have to scream to ya for help if it comes up somewhere down the road. Human nature |
