Oxy / Acetylene carts and firewalls ?
发表于 2021-9-1 00:09:24 | 显示全部楼层 |阅读模式
in this months issue was talk about firewalls being on our carts... is that for use and storage or just storage ?going to OSHA site is seems to me just storage. whom have 49 CFR and nows what the deal is ?Thanks:MikeMikeHH210Hobart Champ 10KLincoln Buzz BoxCampbell Hausfeld 115Victor JourneymanMilwaukee 14" Chop Saw7" Chop Saw4/12" horz band sawmetal benderother toys forthcoming.
Reply:Its for use where i work on any set of tanks. I even see new racks with the divider plate factory installed...BobBob WrightSalem, Ohio  Birthplace of the Silver & Deming Drillhttp://groups.yahoo.com/group/southbend10k/http://groups.yahoo.com/group/sawking/1999 Miller MM185 w/ Miller 185 Spoolmate spoolgun
Reply:Pardon my ignorance on this, but are y'all talking about a plate that goes between the two tanks or in front of them?  I have an OA setup in my garage, and securely wall mounted a 1/4" strap around both tanks to keep them from falling over.    I have some unused stock that I could stick between them, or in front.  How would you recommend I arrange this?
Reply:Yes there is a plate that goes between the ox/act the width and height of the bottles...BobBob WrightSalem, Ohio  Birthplace of the Silver & Deming Drillhttp://groups.yahoo.com/group/southbend10k/http://groups.yahoo.com/group/sawking/1999 Miller MM185 w/ Miller 185 Spoolmate spoolgun
Reply:Firewalls...Between the tanks.... We just had a inspection and there was no mention of this... Do you mean to say every garage and wherever in the world that has oxy/acc has to have these now??This is what I say..    Go ahead and try to inforce this now...I know I'll get crap for this but You've got to be kidding..Dont expect very many changes soon..   ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:I read the osha articles above amd they said a steel plate 5' tall between the tanks. My tanks are only a foot tall  ...BobBob WrightSalem, Ohio  Birthplace of the Silver & Deming Drillhttp://groups.yahoo.com/group/southbend10k/http://groups.yahoo.com/group/sawking/1999 Miller MM185 w/ Miller 185 Spoolmate spoolgun
Reply:if someone wants to spend a month reading;http://www.osha.gov/pls/oshaweb/owad...ARDS&p_id=985429 cfr 1910.253Words of caution, don't confuse the words "storage" with  "used in" or "used for" and things like that. Storage tanks are those that are not a part of the equipment.  Don't confuse flammable liquid regs with everything that goes ca-boom.Add this link; http://www.osha.gov/pls/oshaweb/owad...RDS&p_id=10696Last edited by Sandy; 06-07-2007 at 10:11 PM.
Reply:In Canada safety regs just changed now so you must have a seperate storage for acetylene/flammable gases . Must be at least 20 feet from other gases, oxygen,nitrogen etc. WE just had to buy another bottle cage for that. No mention of firewalls on the tanks in use.Latest Toys Miller 180 Mig and Elite Mask!!Wright Welder 225ACShop OutFitters 20/20 Bending SystemHypertherm 380 Plasma30 Years of Sparking (Electrical & Welding)
Reply:In the U.S. if I recall correctly, the separator plate is needed in any shop that is covered by OSHA regulations. That would be any shop that has employees covered by the regulations. If you are a solo shop you don't need them from a legal standpoint. The separator plates are a good idea in any case.Miller Millermatic 252Miller Syncrowave 200Liincoln AC-DC 225Victor O-A Set
Reply:Howdy,     Here is what OSHA states regarding construction.  Also, as stated earlier, these regulations only apply if you have employees.  The 1/2 hour fire rated wall can be any material you desire, but usually is steel plate which has the appropriate fire rating.  This reg does not apply when you are using, or have the set up ready to use during your shift.  Most large companies are now putting plates on their carts which eliminates the question of "is it storage or is it memorex".Mark1926.350(a)(10)Oxygen cylinders in storage shall be separated from fuel-gas cylinders or combustible materials (especially oil or grease), a minimum distance of 20 feet (6.1 m) or by a noncombustible barrier at least 5 feet (1.5 m) high having a fire-resistance rating of at least one-half hour.Mark WebbSafety Engineer  Bobcat 250Hobart Handler 140My welds look best capped with a grinder,but they hold.
Reply:Gonna have to check up on the Canadian standards then. We usually ollow each other pretty closely (Canada-US) as far as safety standards go.Latest Toys Miller 180 Mig and Elite Mask!!Wright Welder 225ACShop OutFitters 20/20 Bending SystemHypertherm 380 Plasma30 Years of Sparking (Electrical & Welding)
GMT+8, 2025-12-23 11:30 , Processed in 0.111065 second(s), 18 queries .
