weld test@bronze
发表于 2021-9-1 00:09:22 | 显示全部楼层 |阅读模式
i will be taking a weld test tomorrow on a bronze casting. the only info i have at this point is .035 wire will be used; i'm assuming 90-10 or 95-5 gas. any input regarding settings, etc. would be appreciated. also, at this point i have no idea as to thickness; just that it's a bronze casting. thankyou.
Reply:From what I hear, weld like it's aluminum.  Maybe, a little less heat.
Reply:Go to: www.ampcometal.com. They should be able to give you the info you need on welding bronze. Good Luck with your test!!!--------john
GMT+8, 2025-12-23 11:00 , Processed in 0.111178 second(s), 19 queries .
