migging outdoors
发表于 2021-9-1 00:09:19 | 显示全部楼层 |阅读模式
is this even possible? just bought alittle 135 to do some patch panels on my truck and my garage is only a single that can barely fit my truck let alone me on the side of it. is there anyway i can mig outside without worrying about all my gas blowing away?
Reply:It's doable sometimes. If the breeze isn't too strong you can use your hand,arm, body,ect to block some wind. Sometime a piece of plywood can be propped up to give a larger wind break.Tough as nails and damn near as smart
Reply:get some welding blankets and make a wind blockMiller Xmt 350Lincoln Ln-25Ahp 200xSmith Gas Mixer AR/HTig is my Kung FuThrowing down dimes and weaving aboutInstagram http://instagram.com/[email protected]
Reply:unless you are in ahurricane..some plywood  or a tarp will block the wind...
Reply:Plastic tarps.
Reply:old sheets or blankets even. if its sparkin wet them.225NT bobcatAEAD200LEScott 125mm175, mm252 w 30A, PT225mm211, TA 181iHyper Therm 380, cut master 529100X & XX, Digital Elite6 Victor setssmith little torch, meco midget kalamazoo band sawsteel max saw evoulution circular saw
Reply:fluxcore wire...I'm always welding outside
Reply:Originally Posted by IamVincefluxcore wire...I'm always welding outside
Reply:Yes that is one of the main reasons for flux core is you don't have to have a gas since there is flux in the wire to protect the weld from contamination. Gas can be used but is usually not necessary.Lincoln 225 RangerSa200            01 dodge  3500 welding rig
Reply:A sheet of wafer board cut in half and hinged .Set it up in a v shape so it stands alone.Blocks the arc from dumb viewers.Flux core is nasty and leaves a residue that will damage your paint job.
GMT+8, 2025-12-23 11:27 , Processed in 0.096161 second(s), 18 queries .
