Welding on a steel plate
发表于 2021-9-1 00:09:16 | 显示全部楼层 |阅读模式
I was just wondering if using a piece of 1/4" steel diamond plate turned upside down would be a good surface for welding on... I noticed the other day while welding that my plate has a gradual bend in it. the plate is on a plywood deck and I was wondering by welding up to 165 amps would cause it to bend like that. I was given this steel plate by a friend and I will replace it with a fresh straight plate if it wont bend/distort.  I was welding some tubing and I cant get anything to come off perfectly flat because of this...Miller Diversion 165Rage 2 Chop saw
Reply:Ummm, Build a frame; clamp and weld.A example of one...hereCheck out the other projects also for more ideas.Semper FiJesus may have been a Carpenter, but his dad was a Millwright" A grinder and a can of paint, will make a welder what he aint' "I've done so much, with so little, for so long, that now I can do anything with nothing!
Reply:so you dont think my amperage will warp the plate? I would hate to grab another sheet and have that happen to it. Im gonna see what I can get for cheap that is nice and flat.Miller Diversion 165Rage 2 Chop saw
Reply:heat will cause warpage..it is reversible..try laying some weld on the other side of the plate,,,
Reply:I understand that but do you thing I should try to get a piece for 1/4 plate? maybe put a few pieces of channel under it so it acts as a buffer and cools quicker? I dont think that plate that was given to me was ever flat and I definitely dont wanna try to weld on that uneven surface....Miller Diversion 165Rage 2 Chop saw
Reply:are you using 5/32 7018 at that amperage or whatWeldanpower 225 G7Ironworkers Local #24
Reply:You've got to have reinforcement underneath and still hope for the best. If you do anything heavy and repetitive you'll get spots on there that are spit sizzling hot. Just the way it goes. I've got a 1/4 inch top and some decent reinforcement and have still humped it pretty good several times. Sometimes it self heals and flattens out, couple of times it hasn't. Build it, use it and when it's too bad to live with, scrap it and build another one. It's a work table, a tool, you're not marrying the dern thing "untill death do us part" and all that. "The things that will destroy America are prosperity at any price, peace at any price, safety first instead of duty first, the love of soft living and the get rich quick theory of life." -Theodore Roosevelt
Reply:im gonna try several pieces of 1/4 plate laid on some 2" u channel that is 3/6 thick. Hopefully I can make something that will be nice and rigid with the ability to clamp down work. Im picking up the steel on friday will post pics when its done.....Miller Diversion 165Rage 2 Chop saw
Reply:The heating and cooling cycle when you work in the same spot will warp the area over a period of time.  What is the thickness of the plate that is warping?  Plate tops are usually thicker or are channel to last longer against the warpage.Lincoln AC225 and CartLincoln WeldPak HD and CartOne hand
GMT+8, 2025-12-25 11:12 , Processed in 0.097601 second(s), 18 queries .
