Anyone know the math?
发表于 2021-9-1 00:09:16 | 显示全部楼层 |阅读模式
I gotta weld 500 plus ft of 6" kick plate. Should I use stick or a wire suitcase?  Cheaper? Faster?
Reply:I'd wire weld it, it would be faster
Reply:Which math you want to know??
Reply:Ya i know maths.....Do u want any help??????
Reply:Wire is cheaper to buy than rod, wire has a higher deposition rate than stick and it would also be faster. No brainer.Last edited by goinssr; 09-19-2011 at 08:42 AM.StephenMillermatic 251Miller Syncrowave 200Miller 30A SpoolgunHypertherm Powermax 30Etc., etc., etc.............Cancer Sucks!
Reply:are you inside or outside?  what equipment do you have? what processes are you qualified?
Reply:Squeeze the trigger & watch a spool of wire spin or stop & change sticks every 10", DUH !!!
Reply:Does kick plate require full weld seam? Can you run gas or will it be FCAW?Can you maneuver a wire feed where it's at?Does job pay by the hour?  AlA man is judged by what's between his legs...always ride a good horseMiller DialArc HFLincoln Classic 300DThermal Arc 181iPowermax 45Scotchman Ironworker(2) BridgeportsOkomota Surface GrinderAutoCAD 2010
Reply:super glue and duct tape are cheapest with the highest duty cycle rating.I forgot how to change this.
Reply:Is this to be installed on a tower,mezzanine,catwalk etc.?How much weld is required?Might be faster dragging an electrode lead around(stick)than moving a wire feed machine.Miller a/c-d/c Thunderbolt XLMillermatic 180 Purox O/ASmith Littletorch O/AHobart Champion Elite
Reply:Do you have the time to finger f...I mean, play around with the wire feeder when it buggers up and likewise is it feasable to drag it around behind you? (ala, flat surface)
Reply:Originally Posted by Old SkoolSqueeze the trigger & watch a spool of wire spin or stop & change sticks every 10", DUH !!!
Reply:Originally Posted by denrepWhen it's time to move down the 500' job, grab the stinger and an armful of lead and scamper like a monkey.-OR-Let off the trigger and then go through a ball-and-chain like move to gain every few feet.As they say, "DUH !!!"   Good LuckPS - I didn't mention jumping around while tacking to fit and align things.
Reply:Duplicate post, please delete meLast edited by denrep; 09-21-2011 at 05:55 PM.
Reply:Originally Posted by Old Skool. . .what ever works for ya I guess.
GMT+8, 2025-12-25 09:18 , Processed in 0.095928 second(s), 18 queries .
