cold weld iron Ford heads
发表于 2021-9-1 00:09:10 | 显示全部楼层 |阅读模式
Here goes a cast iron cold weld (no preheat). I won't arc weld in combustion chambers/cylinders of engines because I haven't seen that hold up yet.The old "do not make another weld untill you can hold your hand comfortably on it" trick works well for these welds. Identify crack, grind clean surface, start at end and weld about 3/8 inch at a time, peen the heck out of it as soon as the torch is laid down. I checked to see if the crack was through by pressuring with rubber tip blowbill held tightly with pressure on one side and spray soap on the other, it leaked.
Reply:forgot pics! Attached Images
Reply:moreAnother way to determine when its time to make another weld.IR check weld, then check about 1 inch from weld. If welded area is a few degrees colder than area 1 inch away- go with another weld. Peter Attached Images
Reply:ground weli in valve cover area,re-checked and yes it had a couple of pin holes, epoxy over area to seal, or you can keep spot welding the pin holes untill you have them all. Epoxy faster! Attached Images
Reply:Other head, another crack, same weld! Nothing to leak so no epoxy.Peter Attached Images
Reply:The greatest thing I've taken from your posts is PATIENCE.It's hard to learn.  I always want to do it all at once.  I would have made a mess of something like this prior to reading and seeing this"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Originally Posted by farmersammThe greatest thing I've taken from your posts is PATIENCE.It's hard to learn.  I always want to do it all at once.  I would have made a mess of something like this prior to reading and seeing this
Reply:Hello castweld, what filler did you use?Never tried Iron, but would like to some day......(when I can find the time..lol) Thanks Red.Lincoln Percision tig 225 (Water cooled)Lincoln 350MP Power mig (with spool gun )Lincoln GXT 250 With Tig  ModuleLincoln Ln-25 Pro Dual PowerCentury 50 plasma cutter.now Lincoln .
Reply:Originally Posted by castweldThanksPeter
Reply:Originally Posted by castweldTIG rod 99 percent nickel.Peter
Reply:Originally Posted by MoonRiseShould the name of those rods be something like Ni99-$$$$$ ?
GMT+8, 2025-12-25 09:15 , Processed in 0.154842 second(s), 18 queries .
